Question about KitchenAid KSB5 Ultra Power Work Top Blender
Blender has lost top two speeds
My blender only does stir, chop and mix. The puree and liquefy buttons don't up the speed like it used to do - it remains at the mix speed.
Any ideas?
With my blender, some of the buttons stopped working, and I found a simple way that fixed it like new, with no special skills or replacement of parts. To determine if this fix will work for you, unplug the blender and press on each button. As you do this feel and listen for a definite 'click'. If you here it for the buttons that are working, and not for those that aren't, you probably have the same problem.
I discovered that there is a tiny mechanical push button switch under each button. The switches are held snug to the bottom of each button by a thin metal bracket. If you have heavy fingers, the force of pressing the buttons over time, causes the bracket to deform, moving the switches further and further away from the buttons until, eventually, no matter how hard you press, they are no longer close enough to depress the switches underneath.
The solution is to simply open the blender (with the power cord removed) and gently push the button assembly back towards the buttons. To get inside you need to pull out each of the four rubber feet, and unscrew the phillips head screws that are hidden under them. Next, seperate the top and bottom sections by gently pulling the power cord through the strain-relief (don't worry, it goes back together very easily). Before putting it back together, check the buttons (always with the power cored unplugged !!!) for the 'click'. If this doesn't work, you may have to take out the two screws that fasten the bracket to the blender, and bend the bracket hold-down tabs with a plier, in the opposite direction of the switches (that way when you put the screws back in, they'll move towards the buttons. That's it.
Hope this helps someone like me save about $150.00 for a new one and keep another 10lbs. of junk out of the landfill.
Posted on Jul 13, 2009
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Two buttons are stuck in on my kitchen aid blender.
I have been searching for an answer to this same problem. My chop and mix buttons were stuck and I was getting no power or blinking lights. After finding no help on-line, I decided to take it apart and fix myself. It was easy and it worked!
1. Take the bottom of the mixer off by removing the rubber foot pads and remove the exposed 4 screws.
2. Remove the 3 sets of wires that are attached to the inside panel with clips. Very easy to remove, just squeeze at the base of the clips and pull up.
3. Remove the 2 screws holding that panel in place and gently lift off.
4. Remove the panel found under the top panel by also removing 2 screws. When you flip this panel over you will see what operates the switches.
In my blender the black plastic nubs that push against the buttons that were stuck and got twisted off kilter so they were not resetting properly. I just put a small screwdriver in there to try and straighten them as much as possible. All of these steps will be obvious as you disassemble the blender.
5. Push on the back of the buttons that were stuck to get them unstuck before reassembling everything back together.
I was surprised how easy a fix this was and how obvious what the problem was when I opened the blender up. No soldering or fancy tools needed, just 5-10 minutes and a phillips head screwdriver!
May 21, 2013 | KitchenAid KSB560 5 Speed Blender
Can you use a 5 speed blender for juicing?
Yes,a 5 speed blender can be really good for juicing. If you are really into yourjuicing, check out this article that reviews 5 speed blenders.
Jul 17, 2012 | KitchenAid 5 Speed Blender - Metallic...
Salton Blender
Contact the manufacturer of your blender, if the manual is around look in the last pages.
Oct 23, 2008 | Salton FBL500SS 3-Speed Blender
Westinghouse inteliblender
Mine developed the same problem except it stopped blending while I was using it. Being an electrician I opened mine up and put a meter on the motor windings and found that the windings were open. So basically the motor is shot...unless you can find a part number for motor replacement or if your's is still under a might just be easier to buy a new blender.
Sep 27, 2008 | Westinghouse 0101 IntelliBLEND¿ Work...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
KitchenAid 5 speed blender
Are you saying there's something wrong with the blender and it runs on high when it should be running on stir?
Aug 28, 2006 | KitchenAid KSB5 Ultra Power Work Top...
KitchenAid KSB5 Ultra Power Work Top Blender Logo
283 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
