Question about Toshiba gigabeat MES60VK Digital Media Player
MES60VK Gigabeat - Dead
Bought a refurbished 60gb Toshiba gigabeat. Was working just fine until one day it no longer turned on for no apparent reason. Before you say battery dead... nope. Connected to a/c power. Yep, power cord works tried it on another item. Yep, power outlet works several items connected on it and working. All the obvious possibility are working. The gigabeat just wont turn on. Any ideas what it may be?
  • Anonymous Mar 13, 2009
    I have the same problem :|
    Problem Solver:
  • 5 Answers
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
Posted on Apr 04, 2009
When I turn on my gigabeat it shows a picture of a box and a store and says underneath contact manufacturer for repair HELP!!!
I had that same problem before. My gbeat is working fine now after I followed instructions here:
http://www.rockbox.org/wiki/GigabeatSInfo
Read through the link under in Gigabeat S Code Injection Tool. You should be able to dl there the recovery firmware.
Sep 20, 2010 | Toshiba gigabeat MES60VK Digital Media...
I would like to copy or remove music files from gigabeat to my pc.
plug in the ipod, go to my computer and double click your ipod icon, go ta music, and then copy and paste what you want to " my music"
May 29, 2009 | Toshiba gigabeat MES60VK Digital Media...
My Toshiba Gigabeat won't work!
This happens when the Gigabeat battery is run down too far. The only hope is to charge it with the AC charger.
If you don't have one, you can probably get something adequate. The standard adaptor is p/n ADP-15HH, 5V 3A output, center positive, take the unit with you and match the connector - I don't have a useful ruler handy.
If you do not have or cannot get an adaptor, try plugging the device into a USB port and wait at least a day, no kidding. If you can get the port to kick in fir high current, it may come back to life. My Ubuntu box has done it once, as a test.
You can only avoid this by charging the Gigabeat before it runs down too much. This is the real weakness of the Gigabeat, IMHO. That and the problems they get losing the firmware, but that's another topic.
You can sometimes find chargers on eBay, but you will have to pay a little...
Feb 17, 2009 | Toshiba gigabeat MES60VK Digital Media...
Wont turn on
Sounds like the battery is spent. If you just bought this 'new', you should know these haven't been made for a while, maybe 2 years. The battery might be dead. New ones aren't too expensive.
Feb 13, 2009 | Toshiba gigabeat MES60VK Digital Media...
USB Connection Problem
I have the same problem. If you have a large library try letting it stay hooked up for a long time. It seems like it is taking inventory of device then it should work after a while. Sometimes this works. Sometimes I have to unplug then try again in a few minutes.
Aug 31, 2008 | Toshiba gigabeat MES60VK Digital Media...
My toshiba MES60VK wont turn ON
I am having the same issues, any luck finding a solution?
Apr 15, 2008 | Toshiba gigabeat MES60VK Digital Media...
Battery is dead
Identical problem - working only with power cord.
Wont power on battery or usb cable.
I actually opened player and check every single option.
(I am experienced electronic - tech.)
Result: battery is fully charged (768 mA/ 3.97V on bench)
Battery switch on bottom fully functional. (switching on/off 3.97V
comming from battery)
USB supply 5.0 V in perfect order.
Conclusion:
There is no "EASY" fix for this problem.
It is either problem with firmware (low possibility)
or semiconductor on logic board (practically not fixable on DIY basis)
I bought my Gigabeat 60Gb for $ 70.00 used on Ebay so
I will live with this problem.
Feb 04, 2008 | Toshiba gigabeat MES60VK Digital Media...
Doesn't work without cord! Battery switch is not responding at all.
There's a "hidden" switch on the lower part that makes it not use the battery. You can switch it with a pencil or pen.
Jan 05, 2008 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK (60 GB) stopped working
There is a little battery cut of switch at the bottom of the device. You can unbend a paper clip and switch it off. Then switch it back on after a few seconds. Plug it back into the usb cable to charge it. It should work ok now.
Dec 26, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba Gigabeat MES60V will not hold charge
I am trying to register an Adobe program on my computer and I can't because the program says my serial number is invalid. It seems like there are many people with this problem.
Nov 14, 2007 | Toshiba gigabeat MES60VK Digital Media...
Toshiba gigabeat MES60VK Digital Media Player Logo
185 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
