Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
No Spin with 2 minutes left in the cycle, the machine is shuting down and beeping. Machine still has water in the bottom of the basin. I tried running the rinse spin cycle, and it is not spinning. Is there a problem with the spin cycle on these machines?
  • Anonymous Dec 01, 2008
    washer wont spin
My washer keeps blinking F02. I try running the rinse spin cycle but it keeps shutting down
Posted on Sep 27, 2008
F02 means its not draining, see if your hose out is clogged.
Posted on Sep 16, 2008
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Posted on Jun 12, 2007
Hf7 130m. Machine will not go into spin cycle.......will not empty water
water pump is faulty It wount spin when it is full of wate. Put waste pipe down low into a basin to drain it out ...then set spin
Dec 31, 2017 | Washing Machines
Will not drain and spin keep beeping with error E20
  1. Remove the 2 screws on the bottom and the front access panel comes off.
  2. Pump is on the right, remove hoses from it, remove pump from machine and remove whatever is in the pump.
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin LEDs should light. Any error codes should be displayed when holding those keys.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 27, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Machine won't empty
It will not spin if there is water in it.
Locate the filter, which should be at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Hope fully this will solve the problem.
Jan 21, 2010 | Bosch Classixx WFC 2465 Front Load Washer
Machine won't spin and rinse and stops with an "OE" message.
it could be as simple as a wire has come off the pump during transport or the pump was about to die.
check if wires have come off pump and if ok then with a little water in the machine see if you can blow some air back down the drain hose to see if there is a blockage in the hose or the pump if there is you will have to remove the hoses from the pump and clear the obstructions
Jun 11, 2009 | LG WM2688HWM TROMM SteamWasher
I can't change the default wash cycle without it switching
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Knocking while spinning
something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Nov 29, 2008 | Whirlpool Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
367 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
