Question about Gigabyte GA-7VA Motherboard
System won't budge
When the power switch is turned on, the fan motors will move one quarter turn. No screen, nothing.
  • nitefly719 Nov 16, 2008
    These were the very things I suspected but I am glad to see that my assessment was the same. Thank you for your speed and professional attention. Good call.
    Sergeant:
  • 306 Answers
Sounds like a power on/power good signal fault. Could be the power supply or the mobo. The voltages can be read at the ATX connector: http://www.formfactors.org/developer\specs\ATX12V_1_3dg.pdf or you can try another if you have a spare power supply to verify whether it is a mobo problem or power supply. Also there are power supply testers but they cost almost as much as an inexpensive power supply. It's an easy replacement task. Steve Medley
Posted on Nov 08, 2008
  • Stephen Medley
    Stephen Medley Nov 16, 2008
    You are very welcome! Thanks for the rating and come back to FixYa if you need further assistance:) Steve Medley
I have a 98 bonneville se. the blower fan only comes on when the knob is all the way up and it ONLY blows heat and absolutely no cold also the air only blows out the defroster and the floor
How did you test the A/C system ? Hook up gauge manifold , test A/C pressures ? Manual or automatic climate control ? The blower motor only working on high means the blower motor resistor is bad ! Did you hook up a scan tool an check high an low pressure switchs inputs to the PCM - engine computer . Does the A/C compressor clutch engage ? turning on the compressor ? Moving the mode switch does nothing . Doesn't move from floor to vent to defrost ? Probably the mode door actuator ! Don't think the HVAC control panel is bad . Just a few little things . Pushing the A/C button on the control panel just send a electrical signal to the PCM , the PCM will energize the A/C clutch relay , turning on the compressor .
The Trainer 40 When the compressor won compress
Blower Motor Problems Auto Repair Help
Do you know how to test automotive electrical circuits ?
Heater Blower Motor Troubleshooting
May 19, 2017 | 1998 Pontiac Bonneville
Where is the motor located for my rear quarter panel windows on my 05 Pontiac Montana SV6? And how do I test it?
Rear Quarter Window Actuator - Right (A20)
Behind the right rear interior body panel
Rear Quarter Window Actuator - Left (A20)
Behind the left rear interior body panel
Rear Quarter Window Inoperative
Did you review the rear quarter window description and operation?
Go to Step 2
Go to Symptoms - Body Rear End
Verify that the rear quarter windows are inoperative.
Do the rear quarter windows operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Are both rear quarter windows inoperative?
Go to Step 4 yes
Go to Step 6 no
  1. Turn OFF the ignition.
  2. Disconnect the rear quarter window switch.
  3. Turn ON the ignition, with the engine OFF.
  4. Probe the accessory voltage circuit of the rear quarter window switch harness connector with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
yes Go to Step 5
no Go to Step 7
5
Connect a test lamp between the accessory voltage circuit of the rear quarter window switch harness connector and the ground circuit of the rear quarter window switch harness connector.
Go to Step 8
Go to Step 10
6
  2. Disconnect the appropriate rear quarter window actuator.
  4. Connect a test lamp between the power window motor rear vents open control circuit of the rear quarter window actuator harness connector and the power window motor rear vents close control circuit of the rear quarter window actuator harness connector.
  5. Activate the rear quarter window switch to the Open and Close positions.
yes Go to Step 9
no Go to Step 11
6
yes Go to Step 9
no Go to Step 11
7
Test the accessory voltage circuit for an open or a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 14
Go to Retained Accessory Power (RAP) Inoperative in Computer/Integrating Systems
8
Inspect for poor connections at the harness connector of the rear quarter window switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
yes Go to Step 14
no Go to Step 12
9
Inspect for poor connections at the harness connector of the appropriate rear quarter window actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
yes Go to Step 14
no Go to Step 13
10
Repair the open in the ground circuit of the rear quarter window switch. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Go to Step 14
11
Repair the open in the appropriate power window motor rear vents control circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Go to Step 14
12
Replace the rear quarter window switch. Refer to Quarter Window Switch Replacement .
Did you complete the replacement?
Go to Step 14
13
Replace the appropriate rear quarter window actuator. Refer to Body Side Window Actuator Replacement .
Go to Step 14
14
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Sep 28, 2015 | Pontiac Cars & Trucks
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Badger disposal has power, inside small blades move but allen wrench only does quarter turn on bottom. I tried a broomstick and it still won't budge. Don't think it is rust since it is only 5 years...
When you turn it with the allen wrench, does it move a quarter turn fairly freely, then stop abruptly? If so there is something stuck in there. (Like a hard piece of bone, or glass but probably metal) Have a helper work the allen wrench while you look down in there with a nice bright light. On the other hand, if it moves a quarter turn but is very hard to turn for that quarter turn, then I am afraid you have some kind of fiber (string, fabric, or tendon) wrapped around the shaft where it would be very hard to get to. If that is the case, you might try removing and plugging the drain hose (that goes to the sink trap) and using some drain cleaner and letting it soak for a while --- but that is tricky because you will have to drain it out the hose wearing rubber gloves and full face protection. Good luck, Al K
Sep 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
At-pl120 getting power from cord, hear on/off switch clicking, opened witnessed contact move, yet no power, zip nothing? any ideas, isaw no fuse inside near power inlet thanks need ansswer asap so i can...
is this belt or direct drive. if its belt try replacing the belt if its direct drive and your hearing it turn on and the platter doesnt budge when you press start the motors blown. I hope This helps, by a Stanton next time not the expensive ones just a nice direct drive table .
May 14, 2011 | Audio Technica AT-PL120 Turntable
Hello, I replaced a light fixture on my existing Emerson ceiling fan. The light worked right away but the blades didn't turn. I could hear power going to the motor so I went back into the switch cup and...
Signs of a bad capacitor in a ceiling fan include:
  • Fan runs slowly or not at all on all speeds
  • Fan will not start but will spin if started by hand
  • Certain speeds are slow or do not work
  • The motor hums and turns freely by hand but will not spin
    The capacitor is usually a black box inside the switch housing of the fan. If this box appears burnt or melted in any way, that is also the sign of a bad capacitor and it should be replaced.
    have a good day !!
  • Feb 17, 2011 | Emerson Fans CF705AW 52" Northwind Ceiling
    Heater is dead
    My 2000 century heater blower died,dont replace the fan motor until you check with a simple test light to see if the heater fan resistor is bad first,it's only 20 bucks to replace.Its located next to the fan housing up against the firewall.The wires from the fan switch go down to the resistor, check to see if switch has power then check for power down at the resistor,I'll bet its the resistor.There are three, I think five sixteenth screws to remove the resistor one is crammed up very tight on the firewall,you'll need a quarter inch drive extension with a wobbly socket to get that one against the firewall.
    Dec 13, 2008 | 2000 Buick Century
    Sharp AL-1642CS Copier, the scanner is jammed
    Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
    Oct 29, 2008 | Sharp AL-1642CS Copier
    P4M-915G/PD1 no screen, no BIOS, only power.
    Do you hear any beeps at all? Do you have a system speaker on the motherboard? If not, plug a 2-pin system speakers onto the motherboard where it says "speaker" and listen for some beeps. You may have a fried CPU or dodgy RAM on your hands. Possibly even a faulty AGP/PCI-E slot, to name a few.
    Sep 07, 2007 | FIC P4M-915PD1 Motherboard
    Gigabyte GA-7VA Motherboard Logo
    101 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Alun Cox
    Tony
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
