Question about Canon Pixma iP6600D InkJet Photo Printer
Canon pexma ip6600d photo printer
I cannot get the ink carriage to move the error code number is 5100
  • gaylekraft Nov 08, 2008
    my error code on my canon pixma ip6600d is 5100 plese send me any advise on this
My friend who is a computor t echnician came to see if he could fix it and he did. he had to go into my pixma ip6600d photo printer from the back of it and tilt it , he then discovered one of the inks were not fully in and thats why it wouldn,t move, he then pushed down on top of the 6inks with a pencil and the inks were all even and they started moving freely again. I hope this works for others as it is a great photo printer.
Posted on Nov 09, 2008
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Getting a 5100 error . put in new ink and camera card it works till hit print then shows an error -5100
5100 means the carriage is not moving freely because of paper scraps inside or grease or ink on the encoder strip behind the carriage. you can try cleaning the strip gently with just a damp Q-tip, moist with water, and look inside for scraps or things that don't belong.
Nov 04, 2009 | Canon SELPHY DS810 InkJet Photo Printer
I own a canon printer MP470.it reads error code 5100 anytime i turn the printer on
5100 is a carriage travel error, something keeping the carriage from moving freely from right to left. Sometimes it is also grease or ink on the plastic strip behind the carriage. You can clean the strip with a damp Q-tip, but very carefully.
Aug 14, 2009 | Canon PIXMA MP470 All-in-One Printer
Service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Jul 28, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Error code 5100 on the canon ip6700D printer. stops printing part way through. Have tried all the cleaning options.
5100 says the carriage is not moving properly or there is ink or grease on the encoder. One time I found a camera card inside stopping it, but usually it's just grease on the encoder strip behind the carriage assembly.also if the purge assembly on the right is stuck in the up position you'll get that error.
Jan 31, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Error message 6A00 on a Canon PIXMA IP6600D
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 17, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Printer is flashing checkprinter 5100
dear bria13,
Code 5100 indicates carriage operation error. The printer performs initialization process (include carriage unit operation) at first time we turn it on. During this process carriage unit will move right and left reading film timing **** strip. If carriage unit can read film timing **** strip successfully then it will move to home position (originally on purge unit part). Otherwise error code 5100 shows.
Here are possibilities and corrective actions:
  1. Film timing **** strip become mist caused by grease or ink; wipe film timing **** strip with moistened cloth.
  2. Carriage unit faulty;replace carriage unit.
Find more article about canon ink jet printer here and please give your rating
Regards,
Nov 09, 2008 | Office Equipment & Supplies
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error 5100 - what does this mean?
Hi Luza, A 5100 error is a carriage problem. That means it could be the code strip, carriage assembly or logic board. First make sure nothing is keeping the print head from moving all the way across the printer. If the smallest thing blocks the head from going all the way across it will generate this error. You'll want to look hard for ANY obstructions anywhere. Throughly check the gears and rollers for obstructions too. Second the code strip (or timing strip) is the 1/4 inch plastic strip that runs across the printer and through the head carriage. It's got supports on both sides. If becomes dislodged it will generate this error. (it's got a tesnsion spring on one end) I have a feeling that is your problem. That somehow when you replaced the cartridges you may have dislodged the code strip. That might account for not being able to correctly align the print head too. Make sure it's straight, level and secure. Also make sure it's not dirty. Grease or dirt on the code strip can generate a 5100 error. You can clean it with a damp cloth (water) but be careful if your going to remove it from it's anchors. You can try cleaning the steele bar that the carriage runs across as well, but you'll have to lube it back up with a cloth dampened with some 3 in 1 oil or a light machine oil. If none of that works and your ABSOLUTLY SURE there is nothing in there blocking the printer then it must be either the carriage assembly or logic board. If either is the problem you're going to need service on the unit or a new printer. I hope this helps. Please let me know how you make out, Dude
Nov 15, 2006 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
182 people viewed this question
old marine
old marine
