Question about Epson Stylus Photo R1800 InkJet Printer
Epson R1800 with magenta blinking ,and wont recognize the said ink
Hi.. i have my R1800 epson..a have problem with the magenta,i wont detect it..wierd thing is i remove all the ink and turn the printer on..after pushing the power the magenta light begin to blink..what could be the problem on it..please help me on this..
  • grace Llacuna
    grace Llacuna Nov 10, 2008
    i already tried those option..maybe the EEPROM..may ill try to change the EEPROM..can somebody send me new EEPROM for EPSON R1800..
    tnx a lot..
  • 1,447 Answers
Try reseating all the ink cartridge, make sure you have the right cartridge for each slot and make sure all are genuine epson in. try another magenta ink as well if you have a spare. if all fails call epson at 5622761300.
Hope this helps
Posted on Nov 08, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Nov 14, 2008
    check on its epson's distributor. check if that part is available.
    Hope this helps
Epson 1400 not recognizing an epson ink cartridge
not necessarily faulty cartridge - had same problem went thru various cartridges some worked some didn't - in fact they weren't epson - so bought epson from office depot and that would not work, so not an issue of ink dried up - if yr printer is fairly old may be easier just to replace rather than waste time and money on trying to figure out problem
Sep 13, 2013 | Epson Stylus Office Equipment & Supplies
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
I have inherited an Epson R1800 printer that guzzles magenta and cyan inks like crazy. Am I doing something wrong?
No, If you are printing any coloured output this will be normal depending on the actual colour content and what most people don't realise is that unless your text is pure black then it will be printed using the color carts as well and not the black ink cart.
Oct 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 paper and ink lights are blinking
See status monitor? Is service required? Reset waste ink, Find resetter at
Jun 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson r1800 both light flashing
try taking out the inks you have installed make sure that you hear a click on each of the inks when you install them. If the issue persists the printer may not recognizing the inks you have installed.
Jun 02, 2008 | Epson Stylus Photo R1800 InkJet Printer
HELP !!!! Instantly empty INK CARTRIDGES Epson Stylus Photo R1800
What i can recommend is call epson and tell them about this issue and for sure they are going to replace the ink and will run diagnostic test on your printer- here is there support line number 562-276-1300
Apr 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 printer won't recognize new ink cartridge
You can remove magenta & double check that some tape was not left behind on the contacts. Take a clean ragg & dampen it with alcohol. Clean the ink cartridge's (copper contacts & inside the the ink carrige). Re-install the magenta, (tight fit). Power off the printer. Wait a few seconds & power it back up. If it fails a second time with no other errors. Like the above. Than the magenta may be defective. Have a recipt? Return it for a replacment.
Feb 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Magenta light blinking on epson r1800e....
Read the manual, says something about turning off for 30 seconds and bac k on again will reset
Jan 05, 2008 | Epson Stylus Photo R1800 InkJet Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus Photo R1800 InkJet Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
