Question about Beverage-Air BM23
Wont cool below 50 degrees
Had no problems until i adjusted the temperature to ferment a lager beer at 45 degrees. adjusted to near 50 degrees for a few weeks and now the unit will not cool less than 50. the coils were really dirty so i cleaned them and still no change. if i turn the thermostat to off the compressor turns off. the fan works fine. its an older unit, the date on the compressor is 1993. i dont usually mess with the thermostat and i wonder if this is the problem or if i need to have the freon recharged. any help would be great because there's beer at stake here. many thanks.
  • Anonymous Mar 19, 2014
    Had dryer replaced and freon checked
  • 237 Answers
Seems like the T-stat may have a dead spot on it since it started when you changed the settings. It is possible to trick (short) the t-stat to cause it to cool FOREVER, that would check your refrigerant charge is good. Would lean more toward t-stat problem first.
Posted on Nov 09, 2006
    Champion:
  • 210 Answers
Check the seal on door, make sure its sealing properly, if yes check coils internal & external, make sure they're clean, check freon level as a last result
Posted on May 12, 2013
3 Suggested Answers
  • 1274 Answers
SOURCE: beverage air dd78e not cooling
change setting on thermostat and see if anything changes. If yes, that's the prob if no, freon level. start there.
Posted on Jul 11, 2010
aaronbeth
  • 110 Answers
SOURCE: I have a Beverage Air
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Posted on Jan 28, 2011
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
At what temperature should I be fermenting my beer? Is there a correct temperature?
If you are making your own Ale, then around 65-70 degrees F is a good temperature. Largers ferment better around 50 degreees F.
Be careful because if you ferment your beer too warm it could have an unpleasant flavor. And if you make the temperature too cold, the yeast might stop working. So it's hard to get the balance right but experience helps.
Feb 21, 2013 | Crafts & Hobbies
Does yeast generate heat during the fermentation when you are making your own beer?
On average, a 5 gallon batch of beer will produce around 3 degrees Fahrenheit of heat during the fermentation.
What temperature should beer be at for drinking?
Each style of beer has a certain guideline for suggested drinking temperatures. Here are a few:
- Wheat beer and pale lager= 45-50F
- Pale ales and amber/dark lagers= 50-55F
- Dark ales, porters, stouts= 55-60F
- Fruit beers= 40-50F
Feb 03, 2013 | Wine & Spirits
Does the type of glass you use for draught beer matter in regards to the style of beer?
According to beer manufacturers, yes. This is especially true for wheat beers. Most wheat beer glasses are specifically designed to tall to help trap yeast sediment at the bottom of the glass so that it does not blend with the rest of the beer while you are drinking it.
In terms of beer, what is a lager?
A lager is a type of beer that is brewed at cool temperatures and creating using bottom fermenting yeasts. The most popular lagers are light in color and are generally highly carbonated.
What does the term ale mean in reference to beer?
The term ale refers to types of beers brewed using a top-fermenting process where the yeast is brewed at a warmer temperature (15-24 degrees Celsius).
Jan 10, 2013 | Wine & Spirits
I can't get my keg beer under 48 degrees, even at
clean all coils and fins and filter ...don't block exhaust with anything (should be no sugar left to ferment)
Aug 23, 2009 | Summit Commercial SBC-500 Beverage Cooler
Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Beverage-Air BM23 Logo
878 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
