LG LS50a Windows install cd boots/bios and windows don't see drive
I have a LG LS50a. The dvd/cdrw drive will run my windows recovery disk but the bios shows none on the secondary master spot and windows does not show the drive. I formatted the hard drive and reinstalled windows but it still does the same thing.
Any help would be appreciated.
  • Anonymous May 17, 2009
    i have the same problem can any one help me
  • Anonymous May 19, 2009
    Same problem no response cannot see the partiorions
How to restore from recovery disk after installing a new hard drive
The procedure to restore from recovery disk will vary according to which computer you have. Usually you insert the recovery disc in CD / DVD drive after selecting boot sequence 1 from CD/DVD in Bios. You then push the power on button. Once windows boots from recovery CD it will continue with building up the new hard drive.
Sep 03, 2014 | Computers & Internet
Tip
Forgot Windows 7 Password?
Many people ask me the question that how to recover their lost Windows 7 Password on my site or Email. I know they urgently need to access Windows 7 for different reasons. they are worry that the Win7 OS would be destroyed and their data would be lost. This is not worried and I will tell you the steps to recover forgotten Windows 7 login password.
Notes: You need a Windows 7 Password Reset disk. If you don't have created it before, you should use the Windows Password Recovery Tool to burn a reset CD/DVD or USB flash drive.
Step 1. Download the Windows Password Recovery ToolGo to the official site of Windows Password Recovery Tool, and download it for free. Install it with default options.
Step 2. Create a Windows 7 Password Reset disk Run this soft, insert a blank cd/dvd or usb flash drive. Follow the step-by-step guide to burn a Windows 7 Password Reset disk. You can burn it to a cd/dvd or USB, it depends on your personal condition. After burning successfully, you get a password reset disk. Now insert this password reset disk into the locked computer which you lost Windows 7 Password.
Step 3. Set the bios config to boot from cd/dvd or usb
  • 1. Start your locked Windows 7 Computer, press Del or F2 button while the computer is initalizing. The initial startup screen may be similar as this image. If you do that, you may see the bios config screen.
  • 2. Go to the boot menu and change bios setting to make it boot from cd/dvd or usb firstly.
3.
Press F10 to save your changes, then restart this computer.
4 . After restart, the computer will automatically load Windows password Recovery Tool and you can start to reset Windows 7 Password. let_me_help_4.jpg
Step4. Recover Windows 7 Password with the password reset disk.
  • 1. Choose the Windows 7 Installation if you have more than one OS in this computer.
  • 2. All Windows 7 users will be listed. Select the user name which you forgot its password, click reset button.
on Apr 03, 2011 | Computers & Internet
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
Forgot password on dell laptop with windows 7?
emm, forgot Windows 7 password?
There are some methods for you to reset it, just follow the info and have a try
Option 1: Use a password reset disk to reset lost password if you have created one before forgtting the password.
requirement: USB flash drive or floppy
time: a few minutes
Note: This password reset disk can be only created when you can log on with the lost windows password.
Option 2: use a freeware to crack lost windows admin password, then you can get back the password, like Ophcrack
requirement: download Ophcrack live cd,
time: more than i hour
Option 3; a high efficient and easy-to-use low affordable shareware, like Windows Password Recovery Tool, which can reset windows 7 password quickly and successfully.
Requirement: a bootable CD/DVD or USB flash drive.
Time: within a few minutes.
Visit http://www.windowspasswordsrecovery.com
Step 1: Download and install Windows Password Recovery Tool in any available computer.
Step 2: Burn a bootable CD/DVD to remove lost Windows password. (or USB Flash drive)
Step 3: BIOS settings
Step 4: Recover forgotten Windows password with the burned CD/DVD (or USB Flash drive)
good luck ~
Dec 02, 2011 | Dell Inspiron N5030 Notebook PC
I have forgotten my password to my dell c521 computer, not the system password
As far as I know, there are a lot of tools and utilities that can be downloaded and used to recover, retrieve, reset windows password. However, I've tried a couple of these utilities through the years. The free software can help you, but you have to learn some computer skills and waste a lot time on learning. If you want to save more time, maybe Google third party password recovery tool or Google Window Password Seeker can help you.
Dec 01, 2011 | Dell Dimension C521 PC Desktop
Forgot admin password now laptop won't boot up dell latitude d510
are you searching for a bios or a Windows password?
I got a Dell bios master password from
http://master-password.kickme.to/
Jul 29, 2011 | Dell Latitude D510 Notebook
I have an Evesham Evolution desktop with Windows XP SP2 product recovery disc. I want to reformat the drives and carry out full "clean" install and reload all software. I insert the recovery...
It sound like you have a recovery disk not an install disk. The recovery disk you have just lets you repair windows only. If you insert the disk after windows starts and it runs you can then try to back up what you want and delete what you don't want, then run a windows repair. Its the only option, My other suggestion is to purchase Windows 7 and do a clean install.
May 09, 2011 | Evesham Evolution PC Desktop
My kids changed my password and now i have no idea how to get in it now
You may crack the password and login your computer again.
Windows Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
Jan 14, 2011 | Toshiba Satellite A135-S4527 Notebook
I am not able to install it.The windows is recognising the LG player.
Hey,
Cd and dvd drives are installed automatically on windows when they are connected properly. if your drive is not installing then your computers windows has problems, I would insist that you use recovery cd's to restore the computer to original state or use the windows installation cd to install windows to the computer again.
Note that the cd / dvd drive may work outside of windows, so you may be able to install windows with the drive even though it doesn't work in windows. check bios if the drive is detected there or not.
heres some info on the bios, how to get there and how to use it.
http://www.youtube.com/watch?v=Tc1t3c5Yke8
you may need to change the boot order so that the cd starts before the hard drive.
May 05, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Computers & Internet Logo
808 people viewed this question
David Payne
David Payne
