Question about Mitsubishi WS-65613 65" Rear Projection HDTV
Fixed DM board, TV powered on but no Video
I fixed the DM board by putting in new capacitors and tv started but much to my dismay there was sound but no video. Might I have disconnected something to do with video when fixing. If so where should I be looking to make sure everything is connected.
Thanks
    Problem Solver:
  • 6 Answers
I forgot to re-plug something when putting everything back. Now TV is up an running like a champ.
Posted on Nov 08, 2008
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
Oct 21, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a rca 52inch hd52w56 power light on front of set is solid,then flashes ten times,then solid again for a minute. repeats. tv will not turn off or on. ???? screen not on,no picture,no sound,nothing??
DM power board have some dead capacitors.Some capacitors bulge up,best indicatoin it dead,some u must used a multimeter to test.U know how to use a soldering iron and solder?Change all the DM power board capacitors,should get power back to ur tv.Try website Tv repair World.com maybe still selling this refurbish DM power board.
Mar 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Aug 02, 2009 | Polaroid FLM-3732 Television
Green light flashes continuously and you cant turn TV on.
Got nothing but bad news for you. The Digital Module is not booting up. A common problem for that unit. The only proper way to fix it is to have a reputable tv shop pull the entire chassis and ship it back to Mitsubishi for rebuild. It is a very costly repair. Usually in the neighborhood of $700 to $800.
Jun 09, 2009 | Mitsubishi Televison & Video
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green led light after power outage will not reset set is approx. 6 years old model mitsubishi w55511
had same problem with my tv.Technician told me to remoe front cover and unplug the 2 plugins going to the buttons then try the mistubishi remote to turn tv on.Did this and worked fine with remote.
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV Won't Power on Green Flashing Timer Light
The green power light is continually flashing and the tv will not turn on. I hit the reset button and nothing happened. I have exhausted all other troubleshooting methods. Please help, what should I do?
Feb 08, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Bulb firing, won't stay on
Try to clean the air filter it soubds as if that is the problem. Then try it aain. If you need further assistance let me know.
Jan 22, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
