Question about Canon Cameras
I have to set the date/time every time I turn on my Canon A720. Once I've set the date/time, it stays set until I turn the camera off.
    Novelist:
  • 208 Answers
YOUR PROBLEM SHOULD BE OVER! ON THE BOTTOM OF YOUR CAMERA IN THE COMPARTMENT WHERE THE TWO BATTERIES GO IS A SMALL DOOR. THIS IS THE CLOCK BATTERY DOOR! YOUR CLOCK BATTERY MUST BE DEAD OR MOSTLY DEAD. AT LEAST IT IS WORTH CHECKING OUT. THIS IS THE MOST LIKELY CAUSE OF TIME DATE FAILURE BECAUSE IT WILL RUN WITH THE MAIN BATTERY POWER WHEN THE CAMERA IS ON, BUT WHEN YOU TURN IT OFF, THIS SMALL BATTERY IS SUPPOSED TO KEEP THE TIME, DATE CURRENT IN THE OFF MODE AND IT IS DOING IT! CHECK IT OUT AND SEE IF THIS DOESN'T SOLVE YOUR PROBLEM. GOOD LUCK! HOPE THIS WORKS FOR YOU!!
ARCLIGHT1217
Posted on Nov 08, 2008
Time date stamp needs to be reset every time I turn on the camera, even with new button battery
Upgrade your firmware, or get your little tablet battery checked, the date stamp does not get its power from the reset batteries but a built in one built exclusively for it.
Oct 18, 2013 | Canon PowerShot A720 IS Digital Camera
Date has to be specified continuously
Replace the date battery as shown on page 182 of this manual.
Mar 26, 2013 | Canon PowerShot A720 IS Digital Camera
How do I select to have the time and date on the photos I take. The option for this is not highlighted when I open the menu. Don't know why...
The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
Dec 13, 2010 | Canon PowerShot A720 IS Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
Turn date stamp on
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 04, 2009 | Canon PowerShot A720 IS Digital Camera
I have a canon A720 IS with the same problem
arignote,
i have the canon a720IS and was having similar problem with my date/time. once i discovered the small cr1220 battery next to the regular battery compartment, i replaced it but the problem still was there.
i looked closely at the cr1220 compartment and took a toothpick and just pulled the metal prongs out a bit, so that they were in better contact with the cr1220 battery. ever since then i've had no problems.
good luck.
chris c
Sep 07, 2009 | Canon PowerShot S5 IS Digital Camera
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Push the function/set button. Press the directional button down to select Date and Time.
Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Unable to display Date or time in pictures taken from Canon PowerShot A720 IS
You have to select 'Postcard' for the image size -- on the same menu as L, M1, M2, M3, S, Postcard.
Oct 30, 2008 | Canon PowerShot A720 IS Digital Camera
Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
May 27, 2008 | Canon PowerShot A720 IS Digital Camera
Canon Pwershot A720 Date and Time Function
If you are trying to get the date/time displayed in your images, you need to set the recording size (L, M1, M2, M3, S, Postcard) to Postcard. You also need to turn the Date Stamp on in the Recording Menu (Use the Menu button, select the recording tab -- silhouette of a camera, and scroll down to Date Stamp).
Cameras Logo
242 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
