Question about Sony Cyber-Shot DSC-P20 Digital Camera
Takes a picture then turns off
I keep my camera in a bag I didn?t drop it. When I went to use it the camera will take the picture and then turns off. Then when you turn on the camera it does store the picture on the memory. The battery is fully charged, tried to reset it. Nothing seems to work. It still seems to keep doing that. I know it is out of warrantee but I do like it. I don?t know how to fix it. Any help will be good. ~Thanks
  • 215 Answers
SOURCE: "No Memory Stick" errors
Due to the length of the memory stick it rarely causes bent pins sideways but they can over a long period lose their tension and fail to make contact with the memory. Also, more commonly they can tend to get a build up of dirt on them. Try using an old memory stick and quickly push the stick in and out of the camera as fast as you can and do this for about 15 to 20 times (with the camera off of course) this should clean any gunk built up on the contacts. Now switch on and use the new stick to see if it's working. If not try the exercise again. If it still doesn't work try sticking 2 layers of sticky tape to the front (the side opposite the gold contacts)Run the tape from the bottom (the contact end) to the top. Running it to the top will ensure it comes out with the stick when you eject it and it doesn't stay inside causing problems. Doing this will marginally increase the size of the stick and put a little more pressure on the contacts. Just nake sure the sticky tape comes nowhere near touching the stick's contacts as this will tend to make them pick up dirt. Also this trick is only to see if it's you camera's contacts have lost tension, its not meant as a permanent fix. If neither of these tricks work I'm afraid it's a trip to the camera hospital.
Posted on Jul 20, 2006
SOURCE: White screen, won't take pictures, battery door won't open!!
The LCD screen has just come unattached. Take a pencil with an eraser and press on the lower right corner of the LCD screen. You may have to tap it once or twice, but the screen will come back on. As far as the battery door, it sounds like it is stuck on something. Might want to try tapping the end of it to see if it comes loose.
Posted on Aug 08, 2007
After talking to Sony, I'm going to throw it's disposable like all digital cameras. Next time I won't spend as much for a camera. When It breaks, It won't hurt so much to throw it away!
Posted on May 31, 2008
SOURCE: water damage
There are micro fuse on main PCB of camera first check it. If problem is still not solve than do let me know regards
Posted on Jul 21, 2008
SOURCE: E:61:10
It seems to be a mechanical problem that can be fixed by placing a bit of pressure on key points. Here is the fix that I did that seems to have worked fine...
open the battery cover
take the battery out
take the memory stick out (inside the battery case)
leave the battery cover open
carefully remove the 7 small silver screws (put them in a cup so you don't lose them!!)
slightly pry the front cover away from the camera starting at the bottom
wedge something in the side to 'pop' out the top retaining tabs towards the top
the front cover should now pop off the camra
Make small paper spacer #1:
Cut the adhesive strip off of a post it note.
Fold it over again about 5 times so that it has some thickness to it.
Approx final dimensions are 1/8in x 1/4in x 1/32in(??) thick
Stick it in the upper right corner of the black plastic lense housing.
See photos attached.
(There is a nice flat rectangle at that spot about the same dims.
This spacer should fit neatly right over that space.)
Make small paper spacer #2:
Approx final dimensions are 1/4in x 1/4in x 1/32in(??) thick
Stick it in the bottom left corner of the black plastic lense housing.
(There is a nice flat rectangle at that spot, but you want the spacer
to be a bit bigger so that it covers the vertical line in the plastic.)
Put the front cover back on the camera.
Make sure it is mechanically secure, but don't install the screws yet.
Put in the battery and memory stick.
Try it. You may have to play with the spacer thickness to get it to work.
Once it is working well again, then put the screws permanently back in.
Posted on Aug 26, 2008
  • 11967 Answers
SOURCE: Camera won't turn on to take pictures~
Could be a lens problem... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 23, 2010
0 characters
1 Points
Rebel xsi review time doesn't show
Let the camera in the zip bag reach the same cold temperature outside before you take a picture. You may need to warm the battery in your hands/pocket for the battery to operating temperature.
After you have taken your photos, place the camera back in the zip bag so when you return inside a warm house you won't get condensation on the camera/lens. You need to let the camera reach room temperature before you take photos inside the house.
Jan 30, 2013 | Canon Digital Rebel XSi Digital Camera
From your description, it sounds to me like the image sensor within the camera went bad.
This can happen from a few things:
  • Camera dropped
  • Moisture
  • Rattling around in a bag or suitcase
  • Knocking into things while in the pocket
  • Leaving it powered on in the pocket
  • Prolonged exposure to bright lights
Try taking a picture while the camera is in picture mode even if you can't see what it is of, then either review the pictures to see if what you just took shows up without issues or transfer it to your computer.
If you can see a picture afterwards when reviewing your images, then it sounds like the firmware may have gotten corrupted. In this case, you should update the cameras firmware using this LINK.
If you cannot see the image you just took, or it has those same purple lines, then it is a hardware problem and can only be fixed by replacing the camera or by sending it in for repair.
Even if you cannot see the image you just took, I would suggest going ahead with the firmware update to see if it works.
Mar 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
Okay so i've had this camera for quite a long time. i've dropped it before and nothing happens. but recently i dropped it in a parking lot from maybe a foot distance?.. well not far and i could turn the...
Go to the camera store, find a nice replacement, and use the included wrist or neck strap whenever handling your new jewel. Also get a nice dust proof bag, case, thing, to keep it from the elements in.
Apr 24, 2010 | Olympus FE-170 Digital Camera
I went to a party, and i dropped my digital camera ! please help!
You most likely cracked and damaged the LCD. Digital camera's LCD repair sometimes cost almost as much as the camera itself, by the time you add shipping and other charges.
You can still take the pictures, but you will not be able to review them.
Dec 21, 2009 | Fuji Finepix A370 Digital Camera
Please Help. Nikon LCD is green.
sounds as if the camera was either dropped or bumped and the display transistor is damaged.
Your only option is to take it to service for fixing.
please rate our help to keep the free service online
Aug 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Dropped the camera, shutter won't closed, focus keep moving in and out, message "please turn off camera and turn on again"
turn it on and then take hold of the end of the lense and gently oull it and twist it you may hear it click but dont force it. then turn off and on again this may solve you problem.
Mar 23, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Sony Cybershot
Turning on may have killed it. however try this. Take the batteries and card out and leave the doors open Take a polythene bag and place in it a quantity of uncooked rice or salt tied into a suitable cloth. put the camera in and seal the bag. leave in a warm dry place for several days This may save it -or it may not.
Aug 02, 2007 | Sony Cybershot S650 Digital Camera
Why cannot you return this one/ It is a fundimental fault seemingly. Doea it take pictures? Is the battery a good one- you say fully charged how do you know? Try another battery. first.
May 28, 2007 | Nikon D50 Digital Camera
Sony Cyber-Shot DSC-P20 Digital Camera Logo
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
