Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
CD drive door won't open.
For some reason my CD drive door will not open when I push the button. So I can't put any disks in my computer. I've tried everything I can but nothing is working. Help me please.
Thanks
  • jason May 11, 2010
    have you tried a screw driver! (Just kidding! )
    but can you open the computer to get inside to the power plug for the cd drive to see if it is maybe getting a bad connection in the plug?
    Also does the light come on the cd drive when you restart the computer?
    Genius:
  • HP Master
  • 1,250 Answers
There is a very small hole near the push button of your drive, put a pin into it and press it along with the push button
Posted on Nov 08, 2008
  • Robert Kirby Nov 23, 2010
    My HP had the same problem...I solved it with the paper clip in the hole method ...when the tray opened I inserted a blank CD-R and left ir there...now the eject button works fine as long as there is a blank CD left in the tray at all times.
  • 36 Answers
1) There might be a program running in the background that is preventing access to the drive.
I have a CD-Rewriteable that uses such a program to "packet write". The small program by default loads at startup. If a Rewriteable CD is in the drive, that program must be running to eject the disc in some cases.
Many if not all CD-ROMs have automatically executing programs that run when you first insert the disc. If your CD has one of these, the program might not be running correctly on your machine and so the drive isn't accessible.
Does it happen with all of your CD's? If so, you might work around it by deselecting "autorun" in the control panel, system, device manager, CD-ROMs, and then restarting.
You can find out which program might be running in the background by typing "ctrl-alt-del" (once!) while in windows, and looking at each entry in the list carefully, and close one at a time to determine the problem, leave "explorer" alone though. If you figure it out, remove it from the StartUp menu in Start, Programs, or even uninstall it from the control panel.
If none of these are it, then you might have a bad drive, you could try a known good drive in your machine or your drive in another machine to tell. 2) if the paperclip doesn't work
Open your CD ROM casing find the circular motor (the circle shape location right in the middle of the CD ROM) press down that motor and you will find your tray is ejected.
Posted on Nov 13, 2008
I have a Dell Inspiron 1525 with a cd in disk drive. The door will open but disk won't come out. What do I need to do to remove it?
The CD is loose in the drive. You need to remove the CD drive from the computer and then remove the metal case off the drive then you can remove the CD. Put the metal case back on the drive and install the CD drive back into the computer.
Mar 21, 2013 | Dell Inspiron 1525 Laptop
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
How do I insert a CD in my hp Pavilion g7-1365dx notebook PC
Once your computer has been powered up, you can push firmly on the button on the CD/DVD drive faceplate to get it to open. Lay your disk on the face of the drive making sure it is seated fully in the circle provided. Shut the drive door without pushing on the button.
If your drive does not have a door but instead is just a slot, you can push the disk into the drive firmly about half way. It will then be caught up by the computer and be pulled in the rest of the way automatically.
Jan 01, 2013 | Pavilion Computers & Internet
Where is cd rom access
Try opening "my computer" window...right click on cd drive then click on eject...the drive will open.
once you've found your drive you'll see a small button on the front of it...press once to open
Oct 13, 2012 | Medion Computers & Internet
Emachine disk door want open
I'm assuming the CD drive door is stuck and won't open. You will see a small hole in front of the drive. Take a pin and insert it in the hole and push it. The drive should open up.
May 05, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
Toshiba Satellite a135-s2386 won't bootup and CD/DVD drive won't open. The power button, plug button and battery button all come on. I tried taking out the RAM and switching the 2 RAM sticks. I also took...
I assume there is a specific reason that you mentioned the DVD drive won't open. Is it because there is a disk in it that you are trying to remove, and you can't because the laptop won't boot? You can open the DVD drive with a pin or paperclip. There is a little hole in the drive near the eject or open button. Insert a small pin or paperclip straight into that hole and push. It should pop open.
May 01, 2011 | Toshiba Satellite A135-S2386 Notebook
My disk drive doors will not open
hello budy ! the drives door wont open if the drive is not getting power or the drive is bad .
so pls get Another drive
Jul 10, 2009 | Dell Dimension 3000 PC Desktop
My Walmart Computer Care Plan CD is to small/My Dell XPS M1530 CD drive won"t '****' in the CD disk
The tray has a force open button, its a pinhole you need to find a paper clip and stick it in the hole the door will open on its own power and you should be able to get it out.
Apr 22, 2009 | Computers & Internet
My cd-rom
Hi, You should be able to get a paper clip, preferably one of the bigger ones and open it out so you have a straight section of wire, then at the fron of the CD drive you will find a very small hole. Carefully slip the wire into the hole as far as it will go then you will need to push against the manual release with reasonable pressure and the door will come open. Remove your disk and close the door and restart the machine. It may be that the disc became stuck for some reason and froze the drive. Once the offending disc is removed it will hopefully come back online.
If it doesn't come back then the CD drive may have failed, fortunately they are not too expensive to replace anymore.
Oct 29, 2007 | E-Machines emachines (emachinees) CD-ROM...
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
2,322 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
