Question about Apex Digital GT1417DV 14 in. TV/DVD Combo
Dvd tray will not close
I've had this tv/dvd combo for 4 years with no problems. I just pulled out a dvd and in my rush, pulled on the door, helping it open faster, as it was opening. Now it won't close all the way, there is about an inch of the tray that is sticking out.
  • K. Kaylaa Oct 20, 2006
    Thanks!
    Do you susggest opening the TV?
    Keep in mind that I'm a girl that's not really mechanically inclined, but not terrible either.
  • K. Kaylaa Apr 14, 2007
    Five months later... I think it may be best to have this repaired, I don't want to get electrocuted,and I don't have a manual. Any idea what I should expect this repair to cost?
    President:
  • 3,130 Answers
Sorry to say, but you pulled the bugger out of alighnment, and the only way to fix it would be to get a manual and see how it goes together, unless your very mechanicly inclinded and can figure out the loading mechanism. It may be a cam driven loading tray or a gear or belt driven. Also there are limit switchs that a part of the drawer hits to tell the unit when it reaches the fully open postion as well as the fully closed potion. good Luck Please do not forget to rate this thread.
Posted on Oct 20, 2006
  • Larry  Dillon
    Larry Dillon Oct 20, 2006
    If you are safe about this , you should have no problems BUT please read the article I wrote and decide if you think you want to try to tackle this. http://www.techlore.com/article/14550/
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Aug 07, 2011 | Televison & Video
I have dvd/combo Apex GT1417DV. The problem is there is a DVD stuck inside. The disc tray will open and close with no sign of the DVD inside! Any suggestions? (My kids have also loaded a 2nd DVD into he...
Hello
The first DVD you inserted may have slipped into the cabin of TV. It will be there inside, but to take it our you have to open your TV and take the loading mechanism out of it. It is a semi-skilled job, if you have confidence, you can do it yourself. When taking out the mechanism, make sure not
to damage any connection wires from DVD player to main board of the TV. OK.
Jun 03, 2011 | Apex Digital GT1417DV 14 in. TV/DVD Combo
The DVD drawer won't open and close on our Go Video VR3845 combo. Help.
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Dec 31, 2009 | GoVideo VR3845 DVD Recorder/VCR
Dvd polaroid tv/dvd combo tda-o3211c dvd stop
Not worth repairing,just get a seperate DVD player hook to the tv.It very cheap these day.
Dec 05, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Dvd player door is locked and we cannot eject the dvd?
Get a small paper clip.
There should be a little hole on the DVD tray bezel or possibly around the edge. If you put the paper clip into the hole and poke around, it will partially release the tray and you should be able to gently pull the tray open.
Oct 15, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
LG V271 DVD VCR Combo problem
try cleaning the player. with a dvd clean disk..for about $5.00 to $7.00.... and wipe down the player.
sometimes dust and trash gets in the way and will not close properly and you end up closing an closing until the trash get out of the way... cleaning it will help..
Apr 14, 2009 | Sharp DVRW250 DVD Players
DVD Player tray Door Continues to Open
I had this problem and it turned out to be the gears on the door drive. There are two gears, one that engages the rack on the tray and one that has a slot that drives the clamping action to hold the DVD. These two gears were misaligned by one tooth. This prevented the gear with the slot from turning freely after the door was closed.
To fix it I had to take out the tray assembly, disasemble it, and reassemble it with the gears properly aligned. You need to remove the top and back of the case. Then take out two screws at the rear of the tray assembly and three screws on the circuit board attached to the tray assembly. Unplug the connections to that board. Slide out the tray assembly. Now you can pop the top off of the tray assembly by pulling out two tabs and sliding the top toward the rear. Now you can get to the gears to adjust them. The slotted gear should be able to turn freely for about 1/4 turn when the tray is closed. Make sure the pin on the clamping part is in the slot when you reassemble it.
Jan 06, 2009 | Panasonic DVD-S35S DVD Player
DVD won't open
my open/close button doesn't work either. my model is 14PT6107S/05
Dec 11, 2007 | Philips 13MDTD20 13 in. TV/DVD Combo
Dvd Ejection
There is a small switch inside the unit mounted at the door stop, or on a cam that drives the door that is broken or out of alignment. Good Luck
Jul 14, 2007 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Apex Digital GT1417DV 14 in. TV/DVD Combo Logo
1,338 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
