I have a Yamaha RX-V363 AV Receiver. I am using the digital audio output from a Philips LCD TV 42PFL7532D into the receiver (coax connection). Changing television stations causes the receiver to freeze. The power plug has to be pulled to reset the receiver. I have tried another new RX-V363 receiver and the same problem occurs. It appears to be a compatibility problem with the digital output from the Philips TV. Does anyone have experience of compatibility problems between Philips TV's and Yamaha receivers?
  • Capt Grumpy Nov 08, 2008
    Thanks for the help. However, it is not possible to take audio off the HDMI connection at the receiver. Video and audio are switched only by the receiver and then go straight through to the TV. If I want suuround sound from the TV (e.g. free to air broadcasts) then I have to use the coax connection back to the receiver from trhe TV.
  • 9,098 Answers
There is likely a static charge (voltage / difference of potential) between the the receiver and the TV.
They should have their grounds tied together. This should be covered in your owner's manuals.
In some cases, there may also be a stray voltage on the cable line's ground. If grounding the two together doesn't work, you may want to call the cable company (or you or a friend may be able) to check the cable line for a stray voltage or bad ground.
Posted on Nov 08, 2008
  • John Reilly May 31, 2011
    Hi I have exactly the same problem. Was this problem fixed Capt Grumpy?
    Scholar:
  • 131 Answers
YOUR GONNA WANT TO LOSE THE COAX,&USE THE HDMI PORTS ON BOTH,YES,I KNOW THE CABLE IS'NT CHEAP, BUT IT WILL BE WELL WORTH IT.
HELLO MY NAME IS ROBERT. I HAVE A QUESTION. I HAVE A YAMAHA RX-V363. I ALSO HAVE A PANASONIC ST30 PLASMA 3D. AS WELL AS A PANASONIC BLU-RAY. AND DIRECTV HD BOX. HOW WOULD I EVEN START TO CONNECT THE HDMI...
The TV may have HDMI ports, but the V363 may only have RCA outputs.
Video Audio HDMI Male to 3 RCA AV Cable Adapter Audio Video Component DV Convert HDMI to 3-RCA TV Adaptor Line For HDTV 1080P AU https://www.aliexpress.com
Try here.
Feb 17, 2018 | Yamaha RX-V363 Receiver
Not getting on yamaha av reciever rx-v363
IF IN WARRANTY SEND BACK FOR SERVICE...
Apr 04, 2010 | Yamaha RX-V363 Receiver
Connecting cable to receiver
Do you mean 5 RCA audio outputs marked as FrontLeft, FrontRight, RearLeft, RearRight, Center? Unfortunately this receiver doesn't have discrete 5ch inputs (as yamaha calls it on its webpage).
But the cable box should have also digital audio SPDIF output - that is either optical (square connector) or coax (RCA usually orange). You can use this for connecting to receiver.
Mar 07, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
I have a Yamaha Rx-v363 receiver using HDMI jacks but I am not getting any sound through my surround sound only my tv speakers. I have a digital audio optical cable running from the receiver to the blue...
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
Jan 02, 2009 | Yamaha RX-V363 Receiver
No audio after hooking up RX-V363 to TV monitor (from cable box )
The HDMI on the RX-v363 does not pass the audio.  You need to either connect an optical or digital cable from your audio source.  If it is a cable box or DVD player there should be audio outputs in addition to HDMI
Dec 24, 2008 | Yamaha RX-V463 Receiver
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
May 14, 2008 | Yamaha RX-V861 Receiver
574 people viewed this question
 Grubhead
Grubhead
