Question about Mitsubishi WS-65713 65" Rear Projection HDTV
Flashing Green Light
Hey Jaime,
replaced capacitors and the green light turned off and then tv turned on but now I have no picture, I have sound but no picture. Might you have an what happened??
Thanks,
Pete
  • 2,326 Answers
My apologies Pete but I just saw your request until this morning and I was going to suggest to check for any loose or unplug wires/cables.
I'm glad everything worked great for you.
Posted on Nov 08, 2008
TV picture will not display
you have a weak capacitor, I would consult further as this is just going to get worse. If you are to take the back of your tv off, and look for a swollen capacitor and replace it with the correct replacement. You will no longer have this issue. Though I have seen them last forever like that too.
Jan 05, 2012 | LG Televison & Video
Hard time turning on tv. I turn it on, green light flashes a few times then becomes solid green. No picture or sound. I turn it off and light becomes red. I do this at least 5 times before tv will come...
There are some capacitors on the main boardthat are low quality. You can buy a capacitor repair kit on Ebay that contains a set of capacitors to replace the offending ones - about 15-16 bucks. I soldered in the new capacitors and the TV has worked perfectly since.
Nov 11, 2011 | LG 42LC7D-UB Television
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
Blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Dec 25, 2009 | Mitsubishi WD-62825 62" Rear Projection...
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi 56231 Turns on but no picture or sound
HEY DJ SOUNDS FAMILIAR TO ME AS THESE SETS SEEM TO FAIL IN THAT WAY WHEN THE CAPACITORS IN THE POWER BD. AGE/WEAKEN.I PROPOSE A CALL TO A MISTUBUSHI EXPERIENCED TECH THAT CAN REPLACE THE 6 CAPACITORS AND YOU/LL BE WATCHIN' HD AGAIN. JOE TV
Nov 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Static picture or flashing colors pictures wd-52525
HEY AWOOD,THIS SYMPTOM IS DUE TO POWER CAPACITORS GOING BAD IN THE POWER SUPPLY AND THESE CAPS CAN CAUSE A COUPLE DIFFERENT SYMPTOMS,YOURS SEEMS TO BE THE MOST COMMON.IF YOU'RE TECHY ENOUGH YOU CAN REMOVE THE BACK AND GET ACCESS TO THE TWO PLUGS ON THE LITE ENGINE TO TEST (WITH A VOLTMETER) THE 5 VOLT SUPPLY ON I BELIEVE PLUG J19 PINS 1 AND 3.IF LOW THEN REPLACE 6 CAPACITORS ON POWER BD. YOU SHOULD BE ABLE TO SEE IF THEY ARE BAD JUST BY A VISUAL INSPECTION.GOOD LUCK JOE TV
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65713 65" Rear Projection HDTV Logo
144 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
