Question about Nikon Speedlight SB-600 TTL Flash
Sb600 display fine, but no longer flashes
I have a d70 and an sb600. the sb600 strangely no longer flashes. the display works perfectly fine and the batteries seem to be fully charged. the ready light will still blink after taking a shot even though it did not flash. after blinking the ready light will not stay on to indicate that the sb600 is ready for the next shot.
any thoughts on what i can do to correct this?
  • 1 more comment
  • parisneto Nov 22, 2008
    I have a Sb-600 and experiencing the same problem, tryied many things from new batteries and beleive I will need to send to repair anyway. The ready light is steady red, when I take a picture it takes a while ( like it's waiting for the flash to fire ) and the fires without it ... also the test button doesn't produce any light, only the buzzz sound associated with the high capacity volt chargers inside it ( which sound just like it was before ).
    This happened after not using for a few months, so any help is appreciated.
  • spriggsb Jan 27, 2009
    Display works and is able to be changed. Red ready light is on. Flash won't fire, but red light blinksoff and on when it should fire the flash. have checked and changed batteries. Will not work manually firing the flash or on the D90. Has worked to for 1 month.
  • Anonymous Mar 15, 2009
    Mine was working fine and randomly stopped???????????
  • 62 Answers
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Posted on Nov 28, 2008
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon sb600 flash
Auto zoom only works when on the hot shoe of the camera. You also need to make sure that its in the righht mode (make sure that above the word Zoom on the display it doesn't have a "m").
Oh and of course you have to have a CLS (Creative LIghting System) compatible camera.
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Question: Can my SB600 flash be used remotely from my d4ox camera? when taking photos?
For wireless flash you need two things:
1) Something to act as the controller.
2) A remote flash.
While your SB600 will work fine as a remote flash, the D40x does not have the 'built-in' capability to act as the controller (as some of the more expensive models do). Unfortunately, you would need a SU800 or SB800 to act as controller.
Matt
Apr 16, 2008 | Cameras
SB600 Works Erratically...
If red light on flash is blinking, flash is charging. In shooting rapidly, sometimes flash will go off even though it isnt fully charged. This can give dark shots. Flash eats batteries like crazy, best to always use fresh batteries for each shoot.
Apr 14, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon SB600 flash behaving strangely
I have sent my SB-600 to Nikon twice in the past 6 months to resolve this problem. They have fixed it both times, but never told me what the problem was. I've had it back for exactly 1 day now, and it's started back up again already. If I receive a solution (or replacement), I'll let you know!
Nov 13, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
875 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
