Question about RCA F27440 27" TV
Won't tune in all channels
My RCA F27440 quit receiving some channels. Not all channels missing are consectutive. Everything else works fine. Tried all on screen setup options and none solved the problem.
  • 2 more comments
  • Steve Smolke Oct 24, 2006
    Internal tuner channels. I just have cable with hooked to the VCR then run to the TV (no cable box). They happened to come back one night after I posted this problem but disappeared again the next day. I am missing channels 2,3,4,5,6,14,15 which are public television, Weather Channel, public television, ABC, EWTN, INSP, and a local programing channel.
  • Anonymous Apr 12, 2008
    I HAVE A CHANNEL BLOCK BECAUSE I FORGOT MY PASS CODE, CAN YOU HELP ME?
  • Anonymous May 04, 2008
    I HAVE AN OLDER RCA TV. JUST CONNECTED THE hdtv CONVERTER. I CANNOT GET LOCAL CHANNEL 6 AND 8 WITH MY RABBIT EARS. WHAT CAN I DO.
    THX
    DI
  • jvaldez May 11, 2010
    The internal receiver doesn't work. Have an external receiver, but the set won't recognize it. I get 2 messages. Weak Signal and the other message is insert a valid access card.
  • 65 Answers
Assumptions .. you are using standard cable and not over the air signals to the tv tuner directly do a channel scan with the tv set for over the air and then for cable these products were known for bad tuners and gemstar modules the rca boxes are in french and pictures of dogs on them
Posted on Dec 09, 2006
    Scholar:
  • 68 Answers
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Posted on Oct 22, 2006
SOURCE:
RCA TruFlat 27F520T 27
Just check this TV by connecting it to on-air programs. Connect external antenna to it, and make an auto tune function. Refer to its user manual for details. If TV do not tune in to on-air channels too, the tuner to your Tv should be checked and replaced. If it receives on-air channels, and only cable channels are missing, you must contact the service provider to your cable connection.
Jun 19, 2012 | RCA TruFlat 27F520T 27" TV
Can't select front input without remote
I had the same problem, had a universal DirecTV remote that was able to control the volume/mute, power and channels (both TV and DirecTV), but the input button didn't work. There was no av/tv button on the front of the tv, and the autoregistration of channels didn't pickup the gamecube on the AV channel. What solved it was simply to press "00". I couldn't believe it, but it was that simple. Hope this helps you like it helped me, since the tv was not going to be of much use since we were using the RCA inputs, not the coax. Didn't want to try to conver the RCA to coax either.
Apr 04, 2009 | RCA F27440 27" TV
Bad main right channel ( no out put at all )
I had the same issue with this same receiver. Unfortunately this is a known problem with this receiver and Yamaha knows about it. The usual fix is to have the input RCA connections in the back replaced to some updated ones. What has happened is that there is a shirt created using the current RCA input jacks and it is actually turning the internal amplifier off to that particular channel or channels. My local stereo shop ( who is a Yamaha authorized service center) knew about this and replaced mine to the tune of $200.00. Good luck
Mar 29, 2009 | Yamaha RX-V1 Receiver
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Mar 22, 2009 | Televison & Video
Hi I am having trouble getting my DVD player to work with my RCA F27440 TV. It worked fine with my other TV. Can you help?
If there is not a TV/Video button on the TV I believe that RCA uses channel 00 (zero zero) for the video input.
Jan 04, 2009 | RCA F27440 27" TV
No channel line up in guide plus
Tune your TV to a Public Broadcasting Station before turning it off for the night. You should receive your line-up.
Oct 26, 2008 | RCA F32650 32" TV
Brookstone Wireless Rechargeable Speakers with auto-tuning
its probably the interference with the routers. try getting internet by bypassing the router. much easier sound quality.
Jun 12, 2008 | Brookstone Outdoor Wireless Speaker...
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
Sep 04, 2007 | Mitsubishi CS-27205 TV
RCA F27440 27" TV Logo
302 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
