You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
it should be beneath the slot u installed the memory on both slots are next to each other one on top the other beneath i fu dont find it tell me exact model number to help u more in this
Yes, you can upgrade from Win98 to WinXP. The minimum hard drive requirements for WinXP is 1.5GB and the minimum RAM requirement is 64MB. You will also need a CD ROM for the install. Now those are the minimum requirements so don't expect it to go very fast. If possible I would recommend you upgrade to Win2000. WinXP and Win2000 are almost identical. The minimum hard drive for Win2000 is 650MB and for RAM it is 64MB. So you could still use your 4GB hard drive and have plenty of room. You will need a CD ROM for the Win2000 also. Good luck if you have anymore questons let me know,
Don't forget to rate this solution before you log off.
