Question about Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker
Dough does not rise
My Zojirushi BBCC-V20 completes the cycle but the dough does not rise at all even with very fresh ingredients - yeast flour and eggs. Tried 3 times but no success.
  • Lee Birkhead
    Lee Birkhead Apr 13, 2014
    If yeast is slow it could be old unless you store it in frig. I freeze mine but let it warm to room temp before using. also try proofing yeast to get it started before putting it in the mix. Mix yeast with 1/4 or 1/3 cup warm water one teaspoon++ sugar. I have a similar problem but mine is warm cycle is too hot killing yeast
    Genius:
  • 1,689 Answers
Make sure you are following the recipe very carefully. You have to have the proper type of four, and yeast. Make sure you are using flour that is called bread flour. This type of flour has higher glutent than cake flour. Cake flour would make a heavier bread.
As for the yeast, there is a special yeast for bread machines. Regular yeast would be too slow acting for most bread machines.
Jerry G.
Posted on Nov 08, 2008
How long does it take to dough to rise?
That depends on many different factors.
1. The amount of yeast you added.
2. The amount of salt you added.
3. The heaviness of the dough.
4. The amount of sugar you added.
5. The age of the yeast you used.
6. The type of yeast you use (dry, fresh, fast raising, etc)
7. The temperature you keep the dough (the cooler the longer).
8. The type of flour you use.
9. etc.
Jul 17, 2014 | Baking
The dough will not raise no matter how fresh the yeast
Check the type of flour you are using. In the US, if you are using white flour you need to select the type that is labelled "for bread". Also, do not open the lid while the bread is supposed to be rising or you will make it fall. It needs to have a steady temperature while it is rising. Also, make sure that the measured quantities are quite precise. The heavier the ingredients the harder it is to make the dough rise. Adding a little extra water can help.
Mar 05, 2011 | Black & Decker B2250 Bread Machine
My bread does not rise properly. Is it possible\r...
If the machine is heating the element is working.
If it looks like bread dough then the paddle is mixing.
It's more than likely your ingredients. Old flour, old yeast, not enough flour, not enough yeast, water too hot or cold.
Check each ingredient to the recip as you put it in. Put them in in the order suggested by the recipe. The yeast should go in last and shouldn't have contact with the water until mixing starts.
May 17, 2010 | Kitchen Appliances - Others
What is the sequence for placing the bread ingredients in the baking container of the bread machine.
How To Make Bread (without a bread machine)
Step 1 What you'll need
You will need: Yeast - 2 Tbsp Hot-ish* water - 2 cups Bread flour - 5 cups total, 2 for the sponge and 3 for later. (NOT regular flour) Sugar - 2 Tbsp. Salt - 2 tsp. Oil - 2 Tbsp. 3 loaf pans Quick-read thermometer Oven pre-heated to 375 *Hot-ish means betw…
Step 2. Make the sponge
This recipe uses what I call a "sponge." The sponge will activate the yeast and get things started; getting the yeast warm, happy, and ready to go Start by mixing the hot water and the flour. Then, add 2 Tbsp. sugar, 2 Tbsp. oil, 2 Tbsp. yeast, and 2 tsp. salt. Let this sit for about 8 or 10 m…Step 3. Add some flour and knead it
Now you need to add about 3 more cups of flour. I added a little less this time, it really depends on the humidity and how exact your measurements were in the sponge step. Once it gets too tough to stir, flip it onto a clean floured surface. Now, knead away, adding flour as you do so. Knead th…Step 4. Let it rise...
let the dough rise in a warm place for about 45 minutes to an hour. the dough should be about doubled in size by the time it's finished.
Step 5. Into the pans
Punch the dough down (Yes, punch it. Beat the heck out of it. Just don't make a mess), then divide it into 3 parts. Spray the pans and put the dough in. Let it rise again in the pans (covered) util it looks like the second picture.
Step 6. Into the oven
Preheat your oven to 375 F and put the loaves in. Bake them for about 25 minutes. Your quick read thermometer should read between 180 and 190 degrees. Pull the loaves out and place them on their sides on a rack, after a few seconds slide them out of the pans and onto the rack. Let them cool.Step 7 Eat!
Eat it! Share it! etc.! You can do a lot with this recipe... ...You can add nuts, roll it out and add cinnamon and raisins for cinnamon-swirl bread, add your favorite spices, etc. Add sweet potatoes, chunks of cheese, pieces of ham, or whatever suites you.
Also, here can find few recipes about making bread recipes
Hope this helped.
Jan 24, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
My breadmaker model BBCC-V20 completes the entire cycle, however the dough does not rise at all! I've tried with brand new ingredients eggs bread flour and yeast. Tried 3 times - no success at all.
Hi ravimalini,
Something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the new yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
You might be able to get more product-specific assistance from Zojirushi.
I'd go to Zojirushi's Support page at (TinyURL'd for brevity)
http://tinyurl.com/3jmx4g
There's a Service & Support link at the top of the page - locations of service centers and the like.
You can also call Zojirushi Customer Service Department - -
800-733-6270, M-F, 8:00 a.m. to 5:00 p.m. PST.
Also here's a TinyURL for the manual download page, just so you have it.
http://tinyurl.com/z39gu
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Nov 07, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Rising cycle
Have you 'proofed' your yeast? The rise temperature is not very much above room temp, particularly in the summer months. I would expect the bread to rise at least 3/4 as much without any rise time heating.
Jul 07, 2008 | Zojirushi BBCC-V20 Home Bakery Traditional...
Dense, heavy loaves
Hi nanearl,
(A personal aside - my personal experience with home-baked bread is that it tends to be a heavier product - - but that may be because the recipe gets experimented with, and whole grain flours tend to be used rather than bakers flour.)
It sounds like something is stopping the yeast from acting (fermentation creates to CO2 bubbles that cause the bread to rise). Was the yeast you used all from the same batch? (sometimes they have bad days at the yeast factory, too). Can you watch when it runs through the cycle, and check for conditions _before_ the dough is supposed to rise? If it heats up much too quickly/soon, the heat can kill the yeast before it get to do it's job.
Jon
Feb 16, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
Need bread to be lighter, more fluffy
To make it light and fluffy you need to add more water or milk so that the dough is sticky, also add a little more yeast. You will have to experiment to get the right quantitys but as a rule if the recpie adds 2 tsp of yeast i add 1 more, with the water if it aske for 10ml extra for every 100gm of flour.
Oct 19, 2007 | Zojirushi BBCC-X20 Home Bakery Supreme...
Zojirushi BBCC-V20 Home Bakery Traditional Bread Maker Logo
578 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
