Question about GE Spacemaker JVM1640SJ Microwave Oven
Light bulbs burning out
My microwave has two tubular bulbs for illuminating the range below. One is constantly burning out bulbs (they only last for a day or two). I checked the specs, which call for a 40-watt bulb, and that's what I am using. Any ideas? The other bulb (the left one) seems to be fine. P.S. I did not disconnect the power before changing the bulb, but the lights were in the off position.
  • 2 more comments
  • Charles St. Martin Oct 20, 2006
    The bulbs are incandescent. The socket doesn't seem any more loose than the one that is working fine.
    When the bulb goes, not only the filament is broken, but the metal backing wire as well.
    Both bulbs are Sylvania bulbs, both from Lowe's. I wonder if it's a quality issue with the bulbs. I suppose the least expensive option is to buy a different brand bulb from another store and see if the problem persists.
    Perhaps the attached photo will help (it's not easy taking a picture of a burned-out bulb!)
  • Charles St. Martin Nov 12, 2006
    Apparantly it was a bulb quality issue. I had used Sylvania bulbs from Lowe's. I bought a GE bulb from Wal-Mart, almost a dollar less, mind you, and it has worked fine for over a month.
    Thanks for all your suggestions - and I'll make sure I disconnect the power before changing a bulb (although I don't see how this would matter, because there is no power going to the bulb socket when the circuit is closed).
  • stillfield Jan 23, 2008
    lights under the micro oven burn out fast. use 30 watt.
    thanks
  • juconn May 25, 2009
    I have the same problem, and I too did not unplug the microwave before changing the light bulbs, but the switch was off. The light bulbs that were in there before were in there when we moved in two years before, so I know that they can last more than a month (or in the case of the last two light bulbs, one day.
  • GE Master
  • 9,156 Answers
That does sound odd! On one hand, I would suspect that maybe the door is getting slammed and that vibration may be contributing to the failure. But that would be much more likely for an incandescent bulb than a fluorescent type. Which is yours? You may have a bad connection on the socket which is causing some excess heat. Does the blown bulb look funny on the ends or at the connection? Assuming you're using the bulb your manual calls for, and the socket is okay, it may be a problem on the control board. Once you've digested this reply, let me know what you find and we can take it from there.
Posted on Oct 20, 2006
  • William Miller
    William Miller Nov 11, 2006
    Then I'd say you have a damaged the control panel assembly, which we repair nationwide for $32.50.
    This is indeed caused by not disconnecting the microwave from the power line when removing or installing a bulb, but the lights do not have to be on for it to cause a failure.
    We see this all the time.
    Even though it's not display repair, per se, I would suggest you do a search on Yahoo.com (not Google) for:
    microwave circuit repair
I too am having problems with a GE Spacemaker eating bulbs. Mine are the bottom lights to light a stove top, not the interior oven light. There are two small halogen bulbs. I bought them on-line, the brand is Bulbrite. They are not easy to find, but I will try Lowes or Walmart next.
Posted on Jun 19, 2007
3 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Light bulbs
fan may have a lot of vibration. or the MAGNETRON is kicking back a jolt. or your slamming the door too hard.
Posted on May 12, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: 40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Posted on Feb 14, 2009
I have replaced the bulbs underneath the microwave, but the lights are still not working.
HELLO.
This is the solution to the problem as detailed below.
instruments needed
* Appliance bulb
* Screwdriver.
Unplug the microwave. Remove the lamp cover by unscrewing the mounting screws. Turn the bulb to tightly screw it in. Then plug the microwave back in to test the light. If the bulb still will not illuminate, it is likely broken or defective. Replace it with another 20 to 40 watt appliance bulb.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm2070sk02 interior light does not come on can the bulb be changed?
HELLO.
When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave.
In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
THANKS.
willing to help on more question.
Sep 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Although I have changed the light bulbs, the lights that illuminate under the microwave onto the stove top will not work. This is a Kenmore over the stove Microwave Oven Model 721.80592402. Have their...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Sep 08, 2010 | Kenmore 80599 Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light bulbs
May 12, 2008 | GE JVM1660 Microwave Oven
New microwave problem
If it is new and under warranty, I would refer you to GE so they can fix it free. See the phone number in your owner's manual or at http://www.myapstore.com/Omega/Dispatcher?REQUEST=CONTACTUS
If it's not under warranty, below is info that should help you.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
For GE & Hotpoint models see http://tinyurl.com/gv383
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Nov 24, 2007 | GE JES738 Microwave Oven
GE microwave interior light bulb replacement.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 19, 2007 | GE Advantium SCA1000H Convection /...
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
4,106 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
