Question about Sony Handycam DCR-HC30 Mini DV Digital Camcorder
LCD screen nonresponsive
"Buttons" on LCD screen are nonresponsive
  • 2 more comments
  • rgbonds2 Nov 11, 2007
    My lcd screen buttons are non responsive also. I try to reset the Camcorder but it never does. I have to push the reset button approx 10 times before it resets. Then it works for a day or so and goes back to be frozen. HELP
  • Iocky Nov 22, 2007
    I have the same problem -- I have followed the suggestions for calibrating the screen, but it doesn't work.
    Sony estimated more than $200 to fix it, but that doesn't make sense on a 3-year old camera.
  • vetteshack Nov 29, 2007
    The camera seems to work fine (including the LCD display capabilities), but the LCD buttons do not work at all. Oddly enough when you perform the LCD calibration routine the touch screen responds fine to the touch, but nothing is recognized any other time when attempting to use the LCD buttons.
  • Anonymous Oct 07, 2008
    My DCR-HC20 's LCD touch screen feature is not working too. I did the calibration, it worked fine but on the normal screen it doesn't. This is a 4-year old camera and it's not worth it to have it fixed at Sony BUT good thing I read the solution here coz it reminded me about the remote control (I didn't really use it since I bought the cam that's why I forgot all about it).
    I guess I can hang on it.
  • 73 Answers
If your . . . remote . . . works ok ? your touchscreen internal connector could be loose disconnected - or defective ( not field repairable ) ;
Posted on Jul 31, 2007
I had the same problem with my HC30. i decided to go for broke and open it up to see if any of the connectors had come loose. i opened the lcd part and everything looked fine. that was actually the trickier part to get open (and back together). for the main body of the camera, there are several black and silver screws that need to come out (two hidden under the optional light slot). once the body was open i saw that all the cables seemed properly seated. i did, however, notice that a good amount of the silver backing from some tape had rubbed off on the cables from the lcd screen. i gently scraped that silver from the cables and covered the old tape with a piece of electrical tape. that did the trick. got it back together and all is good. lcd works like new.
Posted on Sep 19, 2008
Bake, broil and clean buttons nonresponsive unless unplugged for hours first
It is most likely the oven control board otherwise known as the ERC or clock / oven control. Contact Circuit Board Medics (www.CircuitBoardMedics.com) to have them rebuild the control board for you.
Jul 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My aria htc screen stopped working yesterday. I have tried to reboot it and it is still nonresponsive. The buttons work, alarm is going off, and incoming calls are coming in but the screen is not...
replacement is the best way to solve this problem,all touch phones are too sensitive nor unrepairable,one of the reason is unexpected falling the phone unto the ground.
Dropping by on the authorize HTC service center will be the best solution.
Jul 20, 2011 | HTC Touch P3450 Smartphone
Nonresponsive touch screen
Clay, it sounds like the digitizer might have went bad when it received water damage. Touch screens are usually 3 parts. The 1st part (the part you actually touch with your fingers) is the outer glass. The 2nd part is the actual LCD that brings you picture. The 3rd part is the digitizer which is plugged in with a small ribbon cable and allows the LCD to sense your touch. This problem is pretty common even without water damage. You can actually purchase a new digitizer on Ebay for between $10-12 with free shipping. Whether or not you decide to attempt the replacement yourself will depend on your background with this type of equipment. It isn't extremely hard but I only say that because this is my area of expertise. You most likely have several areas of expertise that would boggle my mind. If you are unsure at all about installing it yourself, contact someone in your area that you trust to do this. I hope this helps you! Don't forget to vote thumbs up if it does.
Apr 25, 2010 | AT&T Quickfire Cell Phone
The buttons on my Nokia 5310 are frozen
you need not remove only the battery, but the sim card as well.
torn the phone off, remove the batt., remove the sim card, wipe any dust off of sim and connectors, replace all, and power on. This should reset it for you.
If it does not, go to nokia.com for master reset code or contact Tmobile
Sep 19, 2009 | Cell Phones
Locked LG Incite phone with nonresponsive touchscreen
You have to reinstall the rom
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB102425
May 27, 2009 | LG Incite Cell Phone
93 Buick LeSabre with nonresponsive climate control buttons
this system has self testing capabilities, have any GM dealer test it for codes and proper function, If I had to guess I would say the climate control head is defective.
Apr 30, 2009 | 1992 Buick Park Avenue
My 1st gen ipod touch has a white screen that's stuck and nonresponsive
my itouch ipod 16gb was slammed down and has a white screen
Apr 04, 2009 | Apple iPod touch
Open Questions:
See all Sony Handycam DCR-HC30 Mini DV Digital Camcorder Questions
Sony Handycam DCR-HC30 Mini DV Digital Camcorder Logo
282 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
