Question about Pioneer DEH-P5500MP CD Player
I dont know which wires are which
Pioneer deh p5500mp car system im clueless on what wires are ground power and such plz help
    Problem Solver:
  • 6 Answers
SOURCE:
Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
Where to insert the aux cable in pioneer deh - p5500 mp it has an aux option but how?
It has OPTIONAL AUX input. That means unless you bought the OPTIONAL cable, you can't use the AUX feature.
Mar 24, 2011 | Pioneer DEH-P5500MP CD Player
I dont have a wiring diagram for the 16 pin plug on a deh-p2500 pioneer car stereo. Can Anyone help? It is a used unit.
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 25, 2009 | Pioneer DEH-P2500 CD Player
My pioneer deh-p5500mp Car Radio
hmm.. thats a nice radio, not too shaby heheh...
Well your car radio should have a Blue wire with a white stripe for the remote, in case you are interested in the user manual (wich im guessing you dont have)
Go to:
http://www.nodevice.com/user_manual/pioneer/car_audio/deh-p5500mp.html
it has a diagram of the harness and it shows a blue/white remote wire, so im guessing that you bought it used and probably got a different harness with your car radio... but then again thats too weird
you could do a check to see if thats really the problem... just feed 12V From the power terminal of your amp to the remote terminal, that should turn your amp on and you should be able to listen to your car radio's output (id suggest not setting the volume all the way up when doing this XD)
Hope it helps
Jun 23, 2009 | Pioneer DEH-P5500MP CD Player
DEH-p5500mp will not fade F to R
Hello ryan_4run,
The "non-fading" output may be turned ON or the rear output may be set to R-SP:S/W or both.
Press AUDIO repeatedly until NOFAD:ON appears in the display. Press DOWN button to turn non-fading output OFF. Also make sure that the setting for the rear output is set to R-SP:FUL and not to R-SP:S/W.
Hope this helps.
Jun 02, 2009 | Pioneer DEH-P5500MP CD Player
I have a honda im trying to hard wire it directley with the pioneer harness everything is connected right except there is no wire for my illumination wire to connect to. also im getting no power to th
you do not need to connect the illumination wire that is to dim the radio when the lights are turned on. make sure you have +12v on both the red and yellow wire and ground to the black wire. the yellow should be unswitched and the red should be a switched source.
May 20, 2009 | Pioneer DEH-1100 CD Player
Faceplate DEH-P5500MP
dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
Jan 09, 2008 | Pioneer DEH-P5500MP CD Player
Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Jan 21, 2007 | Pioneer DEH-425 CD Changer
Pioneer DEH-P5500MP CD Player Logo
264 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
