Question about Gateway GTW-P42M303 42 in. Plasma Television
2 inch black vertical line near center of screen
My plasma screen has just started having the above line on the screen for all video inputs- I have unplugged the unit for a couple of minutes like Gateway suggessted but outside of that they have been no help. Thanks
  • 10 more comments
  • Anonymous Nov 30, 2007
    I have 2 gateway Plasma 42" TVs
    They both had 2 inch vertical lines one on the left side of one tv. The other tv had the line on the right side. Very identical lines. The one that appeared on the left finally disappeared after months and has not re-occured since. The tv with one vertical line on the on the right now has one more on the left. I accidentally unplugged the tv prematurely before this 2nd line started to appear. Is there an adjustment that I can do myself?
  • A'va Green Devers Dec 01, 2007
    GATEWAY 42" Plasma: GTW-P42M303. MODEL# P420142V5. After 2 1/2 years a 2" black line appeared on the right side near the center of the the screen. Two days ago a second black line appeared near the center on the left side of the screen.
  • Anonymous Jan 04, 2008
    2 inch black vertical line on the right and the left of the TV
  • Anonymous Jan 12, 2008
    My plasma screen has the black vertical line to the right of the center of the screen (as your looking at it). It is 1 month old. How can I fix it? I saw the comment about a "buffer board" but it doesn't say what needs to be done to fix the problem. Replace board? How costly is it?
  • SHANW Jun 09, 2008
    I HAVE TWO BLACK LINES IN A VERTICAL FROM THE CENTER TO THE RIGHT.
  • vtr_racing Jun 28, 2008
    I have the exact same problem with the same TV. When I turn the TV on, there is no line. After about 1min, a 2 inch wide vertical line appears and will not go away. How can this be fixed?
  • shall3609 Nov 25, 2008
    2 inch black vertical line on the right side of the screen and one on the left that comes and goes.
    gateway gtw-p42m303 42 inch lcd tv
  • Anonymous Dec 30, 2008
    i have 3 of the same bars, ive been told to buy a new xr board for $45 dollars
  • rociodrl93 Jan 01, 2009
    i have the same GATEWAY TV and it also has a black vertical line on the right side.PLEAS i need help to fixs my tv.
  • JRC15 Jan 30, 2009
    I have the same problem. The line appeared for 5 minutes last week and would go away. Now it is always there. Thank you,
    Jeff
  • Anonymous Feb 07, 2009
    GATEWAY 42" Plasma.
    2 inch black vertcal line near center of screen.
    A'va Marie Green Devers
    Hello.Is it possible for you to choose one of these pictures to show me what the buffer board is?I'm hoping that you can blow them upif their too small. Ooh. If you only new what I had to go thru to get my camera phone pictures into this email.Please, fell free to use these pictures to help anyone that has the same problem with their Gateway Plasma Television.I just hope that the pictures are not too small to to figure out where the buffer board is.I learned about the over heated circuit board from bernie@nyclubkid .As you can see in the pictures, there is a burnt connector.Bernie, Who also gave instructions on Fix-It gave instructions on how to cut the wire and solder it back on instead. I thought about just replacing that peace.But I don't know what it's called. I call it the "Internal Power Connector".When I went on the web to find it. I saw internal power connectors. But they did'nt look like the one that I need for my tv.Please post any answers and information Thank You. Bye.
  • Anonymous Mar 12, 2009
    I have the same problem. 1.5-inch verticle black lines or bars. Gateway 42" plasma, model P420142V5, chassis GTW-P42M303, manufactured Oct 2003. I agree that the buffer board may indeed resolve this issue. I believe the part number for this board is 6870QSE008E (42V5xxxx.XR). Can anyone out there confirm that these part numbers are indeed related to the buffer board?
If you have a black stripe probelm on your Gateway TV, check out pleasefixitdave@yahoo.com. I asked him for help last year (September '08) and his solution worked perfectly. Still no more stripes (I had 4 of them) and here it is June 23, 2009!!
Posted on Jun 24, 2009
I JUST HAD THIS PROBLEM ON MY MITSUBISHI AND THEY REPLACED THE PANEL IN IT AND IT FIXED THE PROBLEM. LUCKILY IT IS UNDER WARRANTY OR IT WOULD HAVE COST MORE THAN THE TV DID.
Posted on Jun 06, 2009
    Scholar:
  • 50 Answers
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Posted on Feb 03, 2009
    Problem Solver:
  • 3 Answers
What does a buffer board look like?
Posted on Dec 01, 2007
  • 22 Answers
Here you go guys, this will work!  just worked on my gateway!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
stephen
Posted on Apr 28, 2009
    Champion:
  • 217 Answers
It depends where the line is centered most, to the right or left of the center, there are buffer boards that control the vertical video, on the bottom part of the unit if you take the back off and look at the bottom part of the set you will see these address boards, they are usually about 2 inches wide and could be labeled J or K, if the unit is High Definition then you could have these buffer boards on the top part of the unit also
Posted on Feb 17, 2007
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Vertical black lines appear intermitently
Does the line appear on just one input(cable,hdmi,video1,video2,ect) or on all of them? The reason why I ask is it may be just an issue with one input setting on the television and you may be able to use a different input for a temporary fix of the problem. Plasma telivisions run very hot and it may be overheating. Try using a small mountable fan above the TV pointed into the back heat vents and see if keeping it cooler keeps the issue from happening. These TVs are repairable but usually cost more to repair than what it is worth due to plasma TVs are very in-expensive now.
Sep 04, 2009 | Maxent MX-42V1 42 in. Plasma Television
Black vertical line about 3 inches wide from top to bottom on rig
See if you can center the picture in the setup menu. It sounds like it's just off center.
Jan 15, 2009 | Daewoo DSP4210GM 42 in. Plasma Television
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
BLACK LINE
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
Mar 13, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Oct 03, 2006 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Gateway GTW-P42M303 42 in. Plasma Television Logo
1,797 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
