Question about Samsung SGH-a737 Cellular Phone
Security Code I want to delete all messages. When I hit htis a "security code" box pops up for a 4 digit number. None of the obvious numbers worked like 1234 or the last 4 of my phone etc. ATT had no clue and it's not in th emanual as to the solution Any ideas?
  • mickerz Nov 09, 2008
    Angelo 29 is the man! I tried four zeros and it worked!
    THat saved my hand deleting 100 messages. Thanks a million
  • 24 Answers
Try 12345 or 12345678 or 00000 or 00000000
Posted on Nov 08, 2008
How do I retreive messages from the answering machine remotely?
this is pertinent to uniden dect 1653 series and may work on yours as most uniden systems use the same format
1--call your phone number and wait until the system answers( if it is turned off , it answers after 15 rings and sounds a series of beeps
2--- during the greeting or beeps , press the # and immediately enter your security code . If you enter it incorrectly 3 times , the system hangs up and returns to standby
3--- the system announces the time and the number of messages in the memory and a help prompt. It beeps to let you know it's waiting for a command
4--when you hear the beeping , enter , enter a 2 digit code command from from the chart for example to play a message press# then 2
if you don't press any keys for 15 seconds the system hangs up and returns to standby
the chart codes are
#1---repeat message
#2-- play message
#3--skip message
#4 --delete message
#5--stop play back
#6 turn system on
#9---turn system off
#0 hear help prompts
to get your security code -- programming a security code
the default security code is 80
1-- with the phone in standby, open the menu from any handset
2-- select ans setup, the select security code
3-- use the number keypad to enter a 2 digit security code ( any numbers in the 00-99 bracket) Press menu/ select when you are finished
remember to note your security code
if this doesn't work on your set up go google and type in user manual for (make and model ) cordless phones-- and print out any pdf version down loads
Jan 09, 2016 | Uniden Lands Phones
ANSWERING MACHINE
Sherry:
I believe that some how the security code #99 got changed. You may want to reset that code as #99 no longer works. From the manual:
Setting a Personal Security Code (PIN)
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal
Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code"
followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press
menu again."
Note: The PIN code is set to "80" at the factory.
Jun 13, 2014 | Uniden DECT1560-4 DECT 6.0 Expandable...
I have forgotten my unlock code to lg revere
This is copied directly from the manual - check out #5 at the bottom.
Hope it helps!
7.7 Security
The Security menu allows you to
secure the phone electronically.
1. Open the flip and press
[MENU]
2. Press Settings & Tools.
3. Press Phone Settings.
4. Press Security.
5. Enter the four-digit lock code.
The lock code is the last 4 digits
of your mobile phone number if
it is set. The lock code is the last
4 digits of your MEID if your
mobile phone number is not set.
Aug 02, 2012 | LG Revere MobiPhone - Black Verizon...
The phone is locked on flight mode
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
if not solved tell me your IMIE number
type *#06# on your phone to get IMIE number
Still Not Solved
Please type *#7780# to reset to factory settings.
NOTE:Restoring will delete all your datas.
When you give this code it will prompt for security code.Default security code is 12345.If you changed it please enter that code.
It will bring your mobile to factory settings
Aug 13, 2010 | Orange SPV C500 Pocket PC
How to delete numbers off the phone when you text
Here is how to do it on the Samsung M220, maybe it will work for your Samsung phone too:
Menu > Settings> More > Security and enter your lock code (last 4 digits of your phone number)
Select Erase/Reset
Select an option - in this case choose Erase Contacts
thanks
Jul 01, 2010 | LG RUMOR Cellular Phone
I forgot the security code to my phone and i cant
YOU CAN TRY THIS ----->
You should be able to reset your LG 8500's lock code back to the last 4 digits of your wireless number by doing this:
Hit *22899 send (if this doesn't work, try *228 send, choose option #1) to re-program your phone.
Doing this will re-program your phone, and reset the default code. Once you hear the "your phone has been programed successfully" message, select OK. Your 8500 should go off and then back on again. ....... Now you can hit unlock, and enter the last 4 digits of your wireless number.
Mar 29, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Phone security code
Try: Last 4 digits of your cellphone number 1234 0000
If none of those codes work, You will need to call your service provider for the phone security code.
Jan 24, 2010 | Sony Ericsson W890i Cellular Phone
Trying to delete all contacts
Select Erase/Reset
Nov 17, 2008 | Cell Phones
PASSWORD
try the last 4 numbers of your cellphone number
May 15, 2008 | LG VX5300 Cellular Phone
Erasing all phone numbers and user information on A650
FROM THE MANUAL
ERASE MEMORY
Erase memory erases your Phonebook and Voice Dial recordings. This feature is useful if you want to give your phone to a friend or family member.
1. In standby mode, press the left soft key (Menu), then press 9 (Setup), 4 (Security). You're prompted to enter the lock code.
2. Enter the lock code (try the last 4 digits of your phone number unless you set a different one), then press 6 for Erase Memory. A confirmation prompt appears in the display.
3. Use the navigation key to highlight Yes or No, then press OK. A confirmation message appears in the display while your messages are being erased. Your phone then returns to the Security menu.
RESET PHONE
Reset Phone returns all setup options to their factory default.
1. In standby mode, press the left soft key (Menu) then press 9 (Setup), 4 (Security). You're prompted to enter your lock code.
2. Enter the lock code, then press 7 for Reset Phone. A prompt appears in the display asking if you wish to restore default settings (except for the Phonebook and Voice Dial).
Feb 05, 2008 | Samsung SCH-a650
Samsung SGH-a737 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
