FixYa.com
Tags:
Maytag Neptune MAH5500B Front Load Washer
I can't unlock the door (by 5 users)
posted by brave fencer on Oct 20, 2006
The door is locked and won't open and the door lock icon isn't even lit up when the door is locked. The letters keep blinking the letters "FL" on the timer screen after about a minute after I try to start or pause the wash cycle? What do I do?
Comment by brave fencer, posted on Oct 21, 2006
Thanks for your help, Catriver I got the door unlocked and the washing machine is working fine again. Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by kshephe18, posted on Aug 08, 2008
same exact prob. door latched, light not on and door won't open. no luck so far with the listed solutions and i can't find the manual release.
Comment by sbadal, posted on Dec 09, 2007
I have the same problem (FL message and door won't unlock). Service mode procedure did not unlock the door. I removed dispenser, but don't see anything for manul door release. Where is it?Please advise. Thank you
Comment by dr bonz, posted on Dec 06, 2007
I went through the sequence to unlock the door with the buttons and it didn't work. I took off the screws to pull the tab and got the door opened. Now when I go to run the machine I hit the cycle I want and hit start. The machine clicks (as usual) and the door lock light comes on for about 2 seconds then it clicks again and the lock light goes out. The machine doesn't start the cycle after this. I also saw a PF error code once when I was trying to start the machine.
Any ideas?
Thanks so much for you help!
Comment by Guest, posted on Dec 06, 2007
I have the same problem. I did theh door unlock steps but no dice. I had to remove the screws and pull the tab. So now what? Should everything work now? Do I need to call Maytag?
Best Solution
posted on Oct 20, 2006
FixYa! (100)
catriver
Rank:Guru Guru
Rating: 94%, 2548 votes
fencer, you probably have a bad door lock switch. There was a technical bullitin out by Maytag regarding this (TS740). The deal is that the plunger of the switch is depressed but the contacts don't close. The machine control board senses the door is not locked and won't send the signal to unlock it. You can try to put the machine in the service mode by pressing delicates and heavy soils together for 3 seconds. Advance to the board output tests by then pressing rinse. After that press the max extract key to lock the door and the xtra rinse key to unlock the door. See if it works for you. You may want to call Maytag and inquire about the service bullitin, maybe you can get it covered. There is a manual door release in the dispenser section. The pull tab should be toward the front. You may have to remove the screws and remove the dispensor to get at it. Catriver...post back.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Feb 26, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
screws had to be removed to manually release door.
Solution #3
posted on Jun 22, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
IF ANYONE GOING TO BUY A WASHER, PLASE DO NOT BUY A MAYTAG BRAND
Can you Help with these Washing Machines problems?
Keeps buzzing--won't start
Washer display says... Answer This...
Maytag MAH3000AWW
My washer does not always... Answer This...
can someone help me please,,,,,...
the ccu board went bad, I put... Answer This...
Maytab Neptune FL washer
the lights on the panel won't... Answer This...
MAH4000AWQ MAYTAG WASHER
The washer starts, fills with... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
