Question about Fisher and Paykel GWL11 Top Load Washer
Gw608f wont start
Several weeks ago we noticed that the machine kept going when the lid was lifted, and now it will turn on and all the lights go, but when we press "start" nothing happens. i am very suspect of the lid switch, but cant work out how to get to it as i cant see how to get the machine appart.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Posted on Oct 20, 2006
fanny
  • 146 Answers
SOURCE: Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Posted on Nov 04, 2007
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Power and all lights come on, but machine won't go. After lifting the lid to add one more item, the machine will not start.
You did not give the name of your machine which can help in this situation.It can be a faulty timer control or lid switch.
Oct 03, 2014 | Washing Machines
Power Problem with Fisher RS 9015
Glad it helps, thanks also for choosing Fixya for assistance!
Aug 13, 2012 | Audio Players & Recorders
Whirlpool Sm8525079 Rev fills up with water, but won't agitate.
Your lid switch has a fault, Sometimes the switch can bend which means that it won't always operate.
Mar 08, 2012 | Washing Machines
2004 Jeep Grand Cherokee temp gauge high when heat is on
If your "check engine" light is turn on, I suggest scanned the PCM to know exactly what fault code is stored there. Additionally, could be some problem with the "temp sending unit".
Keep us updated.
Jan 23, 2012 | 2004 Jeep Grand Cherokee
Washing machine wont start
Try unplugging the machine for 15 seconds. After it is plugged back it open and close the door several times. I know this sounds weird but it resets the safety circuit that sometimes shut these machines down. There may be some other safety reset sequences specific to the machine (you can search these on the net) if the one I told you doesn't work. Please rate my answer so I get points for it.
Jan 20, 2012 | Whirlpool Washing Machines
94 RANGER NOT STARTING
you need a new fuel relay switch. Its located under hood, drivers side in black rectangular box. lift lid its about 1" square and costs around $7.00 to $10.00 any auto parts store. I had the same problem it gets hot and wont work till it cools off, better to get another.
Apr 03, 2009 | 1994 Ford Ranger Supercab
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
82 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
