Question about HP Office Equipment & Supplies
My psc won't work right . it moves across , but nothing shows up .
  • 446 Answers
The reason why it is moving across is that it is trying to find the home position, if you can look inside your printer and see if you can find ny abnormality, then from there it might help you find out what is wrong
Posted on Nov 08, 2008
The needle hits the base plate of the zipper foot, it works fine on the right side but not on the left, am I able to move the needle shaft across somehow
Depends on your machine. Some machines have the ability to move the needle right and left. Your owner's manual should show how to do that.
Jan 14, 2016 | Sewing Machines
The print cartridge carriage is stalled on HP PSC 1610 All-in-one Printer. Carriage won't go all the way to the right because of a small toggle pin.
If you are tec guy. Open flat bed assm.. check the movement of carriage assm manually, see the obstruction, check service station.ensure that carriage should move freely..close it & check...
Sep 10, 2011 | HP PSC 1610 All-In-One InkJet Printer
The ink carriage is stuck on the right side of the printer & won't move. There is nothing stuck in the printer to keep it from moving.
HI,
This is Neo , remove ink carriage and turn off the printer . Try to move it manually , do it softly . Turn on the printer and add the ink carriage .
Nov 01, 2010 | HP PSC 1410 All-In-One InkJet Printer
The cartridges do not move when I open the top
Wait a few more seconds.
Do you hear any noise (spinning motors) when you open the lid?
If not, then either the motors are dead, or the sensor that reports "lid-open" is not working.
If you do hear noise, but nothing moves, then the cable that pulls the print-mechanism across has broken. It's impossible to replace that cable -- buy a new printer.
Jul 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1400 all in one:I can not change the print cartridge because it does not come in the center after the front cover is opened. Also the check paper light is blinking and is not accepting any paper.
i have had this problem with some of our old epson printers.
How i get round it, is to start the head cleanning mode on the printer and when the gead moves i quickly unplug the printer. if i am quick enougth i can then move the print head across manually.
Not ideal i know but it does work.
Ian
Mar 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer won,t work
I can't get my 1210 hp printer to turn on
May 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
The scanning devise (the light under the glass) will not go all the way across
it is only out of alignment so it is better to have it serviced than disposing it off .
Apr 29, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC will not print
Click Start (windows) icon - Control Panel - Printers. Right click on the HP PSC icon. Set the printer as default printer. Right click on the printer icon and select Set as default. Right click on the printer icon - Select properties - Click on Ports tab - Change the port to USB virtual printer port. Click Apply and Ok. Try to print. If the issue did not resolve. Get back to me.
Dec 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
Paper feed
sounds like print head is not engaging home switch or sensor. open the printer and look for any such switch to sense print head at home position.
Jun 01, 2007 | HP PSC 2210 All-In-One InkJet Printer
20 people viewed this question
Ben Johnson
