Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
200 Harley 1200 Sportster, Shuts off when at idle at stoplight / stopsign, etc.
This Harley runs great when wide open on the road, but lately motor just shuts off when I downshift into a stop and am sitting at idle. Have replaced plugs, plug wires, key switch, checked wiring and not finding any problems. Seems to be getting good fuel flow when under throttle, but when coming to a stop it will just shut completely down. To beat all this is an intermittent problem...does not always do it. Release and reapply clutch and restart, give some throttle and will go down the road fine. I am thinking fuel filter....have a slight miss in 2nd, 3rd gear at low rpm but gets on it at full throttle. Using Exxon premium fuel, recent oil change clean filters....Help!
    Brigadier General:
  • 6,966 Answers
Offhand and initially, pls start by referencing the steps as outlined here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
2005 Harley Davidson 1200 Custom Sportster Stalls at Lights and Stop Signs
4700 not a lot of miles. This motorcycle needs to run. It will be rough until you can get the carb cleaned. I would keep doing what you have been doing for a while. After a couple hundred miles if it doesn't improve, you might want to consider having the Harley shop give it a good tune up. Check the plugs ...
May 28, 2013 | 2005 Harley Davidson XL 1200 C Sportster...
2004 1200 sportster when hot and at idle the motor pops when you rev it to take not all the time
Hi Jim, I think I would go through the carburator paying close attention to the slide and diaphram, also replace intake seals. Good luck.
May 22, 2012 | 2004 Harley Davidson XL 1200 C Sportster...
Recently purchased a sportster 1200 xl low rider 06 plate. Which is great in every way apart from town use, I find that once the engine has got warm I am having to continually blip the throttle to stop it...
Regrettably, it is a "norm" for an H-D Sportster but it's fixable. The engine is jetted very lean in order to meet EPA emission standards. The lean mixture is what causes the spitting back through the carburetor and poor idle qualities of the engine. You can improve the low speed and idling characteristics of your engine by going up one size on the low speed jet and readjusting the idle mixture. If you can do this work yourself, let me know and I'll give you the instructions on how to do it. If not, take your bike to a performance oriented shop and talk to them about it. If they have a dynometer and an exhaust gas analyzer, they can fine tune your bike to where it runs like it should.
Good Luck & Ride Safe
Steve
Sep 10, 2011 | 2006 Harley Davidson XL 1200L Sportster...
I have a 2003 sportster 1200.Do I have to take the carb off to replace the idle cable?
I did not need to on my 93 fl..also ask this ? on harleytalking.com ..the have great info..
Jul 24, 2011 | 2003 Harley Davidson XL 1200 C Sportster...
2005 1200 sportster bogs when idling
It could be any number of things but I would tend to think that it's something to do with the carburetor. It could be something as simple as it's idled too low. The idle speed should be about a thousand RPMs or so.
Your bike also came from the factory jetted extremely lean. A "jet kit' may help the problem in that it will richen the mixture up just a bit making the transition from the idle circuit to the midrange circuit smoother.
Next, you may have a problem with the accelerator pump on your carb. If the pump is not working correctly. Remove the air filter cover and element so that you can see into the carb. With the engine NOT running, crank the throttle to wide open position while looking into the carb. You should see a stream of fuel being squirted into the carb out of a brass nozzle in the throat of the carb. If you don't see this, you need to have the carb serviced.
Apr 14, 2010 | 2000 Harley Davidson XL 1200 S Sportster...
2003 Harley Davidson XL 1200 C Sportster It starts and runs perfect when cold.When it warms up to 150 degrees at wide open acts like it is running out fuel,At 180 does it at half throttle and above,At 190...
That's a strange one. The only things I can think of suggesting are:
  • Clogged gas cap vent. The next time is starts running poorly, remove the gas cap briefly and see if things improve. If so, then the cap is not venting as it should.
  • Moisture trapped in float bowl. Drain the contents on the carburetor float bowl into a clean container and check for dirt, rust, water, or anything else that doesn't belong there.
  • Dirty fuel filter. If there is one, replace it.
  • Air leak between carb and engine. Check tightness of clamps and manifolds for cracking. WD-40 sprayed around those areas with the engine idling will help detect any leaks.
That's all I can think of. Please let me know if any of my suggestions fixed it.
Dec 09, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
Kelhin 40mm cv carburettor harley 1200 xls
No sweat. Screw the idle mixture screw in until it "bottoms out". Do not tighten or you will damage the screw. Back the idle mixture screw out about three turns. Install carburator and check for proper operation.
When you get the bike running, allow it to warm up and then adjust the mixture for highest smoothest idle. Set idle speed to about 1000 rpm with the throttle stop screw.
Oct 06, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Speedo, turn signals, brake lights, horn stopped working. All else is fine.
Gap your plugs to 38 thou. Check all your bulbs (one burned out will affect the rest) Take a look at all your fuses and make sure they are all ok. Otherwise you are probably looking at a wiring short which will require trouble shooting of the elctrical system. Buy your self a service manual for your bike, this will help you a lot.
Jun 03, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Lands Phones Logo
306 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
