Question about Toshiba Tecra S2 Notebook
It's asking for a password and don't let me go into the bios
I bought my S2 second-hand and also bought a brandnew harddrive for it. As soon as I turn it on, it's asking for a password, but it never had one.
I tried different programs, like PowerSuite and also the Windows XP disc.
No matter what key I press..all I get is a beep. The harddrive is formated and has XP on ( done that on my desktop ) .. I'm at the end of my knowledge what to do, so maybe you guys can help. Thanks
  • Ryan Peterman
    Ryan Peterman May 11, 2010
    the cmos trick only works if BIOS is whats password protected...it could be the hard drive itself....did that to myself once... that password will be on the hard drive itself so it wont be lost by removing the battery....so my questions are as follows.. icetiger, did that work or no?...what kind of hard drive do you have?
  • nejasoib May 11, 2010
    do u know where is the location of cmos battery on ur laptop
Sir Please help me soon i have forgotten the bios password and want to get master password.
if you know how,try to take off the small battery inside.if don`t know,ask from a professional .
Apr 02, 2015 | Computers & Internet
Password on Bios of sony vaio VPCEB46FG
You don't need to put a bios password on it.
If the bios already has a password on it then it will not let you boot the computer without you putting it in. It sounds like you are already booted up and into the bios, if that is true don't set a bios password.
May 13, 2012 | Computers & Internet
Hi, i bought my daughter a 2nd hand sony vaio E series laptop it boots up ok but when trying to connect to internet it asks for administrators password does the same when you go into user accounts it came...
You need to clear the passwords, you can do this by using a boot cd called Hiren's boot CD. IT does everything from clear administrator passwords to harddrive passwords and so much more. Download, burn to a CD and navigate to the administrator password reset option. http://www.hiren.info/pages/bootcd
Do Rate
Jul 08, 2011 | Computers & Internet
Hello, I recently bought a dell e6410 bios A04 from ebay I can not get in to the hard drive and when i press F2 on start up i get a message requesting a primary HDD password. i dont have the password is it...
This is a BIOS enabled password. The thing is, if it was a desktop, we can over ride this easily by resetting the CMOS battery. Unfortunately we have a portable system. The password for the BIOS can only be reset/ over ride by getting the generic password from Dell Technical support. Another problem that you have is that you might have bought a second hand computer. This means that your computer is registered in Dell's data base with another person's name. You will need to get those details before Dell Technical Support will help you out. Try to contact eBay so that you will be able to get the account details of the original owner prior to calling Dell.
Jul 07, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
I Have a 945GZM-S2 Motherboard. I want to get into Bios but delete key doesn't work on restart. It would appear that the keyboard is not connected. I have just bought new hard drive and I want to...
The keyboard may be faulty, try a different keyboard, but don't use an USB keyboard because an USB keyboard may not be recognised until Windows is running.
Jun 17, 2011 | Gigabyte GA-945GZM-S2 Motherboard
I don t have the bios password i bought my acer travelmate 4200 second hand and i have a trouble to formate my laptop please help me
press either delete or f2 during the boot process to enter the BIOS you can chage your password from there (be careful)
hope this helps
Aug 13, 2010 | Acer Computers & Internet
Entered built in HDD1 user password
Hello
as the bios was reset the harddrive password was removed from the bios memory.
To get the password unlocked you will need to remove the harddrive from the laptop, buy a adapter so you can connect it to your pc and then do a few things Il tell you about later if your going to do it.
otherwice you can take the harddrive to a shop to be unlocked / reset to defaults.
May 10, 2008 | Iwill P4ES Motherboard
Password for entring my bios
BIOS Passwords Basic settings on your computer such as how many and what kinds of disk drives you have which one are enabled and which are disabled and which ones are used for booting are held in a CMOS chip on the mother board. A tiny battery keeps this chip always running so that whenever you turn your computer off, it still remembers its instructions. A common method of entering the BIOS is pressing the Del key at Bootup other common methods are Ctrl +Alt +Esc and Ctrl + Esc. Most computers have a BIOS which can be configured to ask for a password as soon as the computer is switched on. If the Ask Password option is enabled then as soon as the PC is switched on a Dialog box welcomes you and asks you for the password. You cannot override this and there is no way of disabling this because to enter the BIOS you need to know the BIOS password. So what do you do? Disable it. Now to Disable the BIOS password you need to enter the BIOS. But as soon as you enter the BIOS the BIOS asks for a password. Now the most common method of overriding this password prompt is by trying out the default BIOS passwords. Some common passwords are: Lkwpeter j262 AWARD_SW AWARD_PW Biostar Many BIOS also have their default password that can be tried. "j262" opens most versions of Award BIOS it works about 80% of the time. "AWARD_SW" and "AWARD_PW" work on some computers as well, but much less often. In some BIOS shift+s y x z also works. The best way to find out the default passwords of various BIOS is to search at http://astalavista.box.sk which is the best search engine for security related matter Well if the default passwords did not work them get ready for some serious Hacking stuff. Now as the default BIOS password did not work we will try to reset the BIOS to its default settings so that it asks for no password at all. So to do following: First you have to open the computer and then look for a round lithium battery, it probably looks like a silver coin. So remove the battery and after 30 seconds or so put it back. Some computers may also require you to reset the jumper, so look for a 3-pin jumper and reset it. For example, on most machines you will find a three-pin device with pins one and two jumpered. If you move the jumper to pins two and three and leave it there for over five seconds, it will reset the CMOS. When you boot the machine some BIOS may give an error saying that the BIOS was reset or tampered with, but that is not such a big problem
Apr 30, 2008 | Acer Aspire 5610-4648 Notebook
Toshiba Tecra S2 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
