While trying to re-install software for my HP printer I keep getting this message...FATAL ERROR DURING INSTALL. It then goes on to say: Error 1305. Error reading from file C:/Program Files/HP/Digital Imaging/DocProc/Itkrn 14n.dll. What do I need to do to fix this???
  • 1,183 Answers
The error can be caused beacuse of two reasons, 1. The CD that you are using to install could be missing a file for installation. 2. windows operating system has a software conflict.
Try the following steps
1. Disconnect the printer from the computer
2. Remove the HP cd from the drive
3. Clean boot Xp
Steps to clean boot
loadTOCNode(3, 'resolution'); 1. Click Start, and then click Run. 2. Type msconfig in the Open box, and then click OK. 3. Click the General tab, and then click Selective Startup. 4. Click to clear the following check boxes under Selective Startup: Process SYSTEM.INI file
Process WIN.INI file
Load Startup Items
5. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All. 6. Click OK, and then click Restart to restart the computer.Note To restore the computer to use a normal startup, click Normal Startup - load all device drivers and services on the General tab in the System Configuration Utility, click OK, and then click Restart to restart the computer.
4. Insert the HP cd and start installation , when prompted connect the printer.
Thanks
proton
Posted on Nov 08, 2008
    Master:
  • 505 Answers
1. First of all disconnect the printer from the back of the computer
2. Uninstall the program from Add/Remove program
3. Go to c:Program files and delete the folder HP and all its content if its still there
4. Click start-run and typed regedit. It will open the registry editor
5. Click Edit - Find and type HP. Delete all entries of HP from there
6. Restart your computer
7. disable any frewall or antivirus program
8. Try installing the driver again and follow the intruction. You can download the latest driver from www.hp.com
Thanks
  • 13,433 Answers
First uninstall all software related to your HP make sure everything HP is uninstalled. Reinstall from the CD let me know if the problem comes again, if it does, post the model of your HP printer so I can get you updated drivers online and lets see if those work.
Drop me a comment with the add a comment button.
Thanks, Ekse
    Genius:
  • 2,785 Answers
Plz download the said software there website for free. you will found the drivers in the drivers and software download area in the site. just put the model no of your printer then search it. after that you have to select your os then follow the instruction on the screen.
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Get 'fatal error' during HP C4599 install
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and at what % you get the error is it at 18 % 32 % 56% 94% or 96 % if you get the error at 96% followthe step mentioned below or else please tell us the % at which you get the error
Sep 10, 2009 | Office Equipment & Supplies
Get fatal error message after installationof
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Aug 18, 2009 | HP Office Equipment & Supplies
Crash during install of hp 5940 deskjet software, error 1305
If this is an installation from the CD I would suggest you download from HP's website and retry ...
Go here
Jan 19, 2009 | HP Deskjet 5940 Photo InkJet Printer
Fatal Error while install software for HP C8180 printer, Vistax64
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Fatal error msi.webreg
hmm..did you run disk clean and defrag, after uninstall?
Jun 16, 2008 | HP DeskJet F380 All-In-One Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
jasbo
jasbo
