Question about Dell Dimension 2400 PC Desktop
Power does not turn on, even I press and hold down the power button
    Problem Solver:
  • 14 Answers
If your computer is showing no lights at all open case,
lift up the green trim covering the cpu heatsink,
look to left side of heatsink and check caps, (see pic 1)
if they are bulged then your motherboard needs replacing,
if not replace power supply, (see pic 2)
This should of fixed your problem,
these are the two most common problems with all computers,
RATE ME!
Nathan
Posted on May 11, 2009
  • Dell Master
  • 1,183 Answers
If the system is not coming on when you press the power button, the probable cause is a bad power supply.Follow the troubleshooting steps given on the following link
http://tinyurl.com/5e42gq
Thanks
Proton
Posted on Nov 08, 2008
    Genius:
  • 2,785 Answers
Plz try with a new power supply unit. if your problem is not solved then *********** board needs repairing
Canon Pixma MG6650 waste ink absorber full
hi, you have to remove/or replace the ink absorber pads, or perhaps wash them out. the printer then needs a reset.ie hold in power button to turn off, then hold in power button and keep holding in until printer starts and then turns off. that should reset it(clear any registered faults). it should now start ok.
Nov 09, 2017 | Canon Office Equipment & Supplies
What does service error 5C00 indicate?
Waste Ink Counter Reset due to residual ink in the ink docking station only resolution apart from replacing the printer.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
With the printer powered off (but still plunged in), hold down the "Resume Button" and press the "Power Button" and hold them both down.
While holding down the "Power Button", release the "Resume Button" and then press and release the "Resume Button" twice.
Now release the "Power Button".
The indicator light should blink in green and the printer will make some noises.
You know you are in service mode if the green light stops flashing and stays green.
Select one of the following service mode functions by pressing the "Resume Button" the specified number of times listed below.
Each time you press the "Resume Button" the light will change color to let you know the button was pressed.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
(4 times = Waste ink counter resetting)
5 times = Destination settings
6 times = Print head deep cleaning
Then press the "Power Button" one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
To Re-iterate :
You have to be pushing down on the resume button or the printer will just turn on when you press the power button.
Startin over.
Hold down the Resume Button then press the Power Button and hold them both down. The light between the buttons should come on green but the printer should not turn on. If the printer turns on at this point the printer does not recognize that the Resume Button is being pressed.
While still holding the Power Button down release the Resume Button and press it again twice. At this point the green light should change colors each time the Resume Button was pressed.
Then release the Power Button and you should be in service mode.
Once in service mode if you press the power button without first pressing the resume button the printer will turn off
Mar 31, 2016 | Miscellaneous
How do I get out of Safe Mode?
Hi Claudia. I found this.
I found Please remove leather case on your kindle before performing the steps below.
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or Shutdown. If it prompts for Shutdown then please shut down the device and power it back on.
That should fix the problem.
If the answer to your question was informative and helpful, please show your appreciation for my efforts by clicking the green Accept Answer button right below my first response.
Thank you for choosing Experthelp.
Safe mode turns on when you shut down the kindle while the volume button is being pressed down. Solution-Restart your kindle by holding the power button until the screen shuts off. Make sure that the volume button is not being pressed while you restart your kindle. Then keep pressing the volume button, about 10 times to unstick them then turn on the kindle. Safe mode should turn offand how you go into it.
and I found this
Jan 17, 2016 | Amazon Kindle Fire HD
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
I have a IP3000 Pixma and the waste ink absorber is full. Where is the waste ink absorber and how do I access it to clean it??
The absorber is at the bottom of the printer but you don't have to clean it. Even cleaning will not make the printer work. All you have to do is reset the ink tank counter. Here is the procedure:
1. Turn off the printer.
2. holding down Resume/Cancel press POWER - indicator goes on green.
3. release Resume/Cancel, continuing to hold down POWER.
4. press button Resume/Cancel 2 times holding POWER, then release all buttons.
5. when the indicator illuminates GREEN - press button Resume/Cancel four times
6. turn off printer pressing POWER.
Aug 05, 2010 | Canon Pixma iP3000 All-In-One InkJet...
The off and on button is on but the screen says it is shutting down, but it will not shut down or let me go on to another stage. I have pluggged and unplugged it. It still comes back to shutting down mode
Hi
Try resetting the printer, follow below steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
Regards,
Rizwan
Jan 27, 2010 | HP Officejet J5780 All-In-One InkJet...
I just tried powering up the laptop, and the power light keep flashing and it is not booting. It will not power off even when I hold down the power button. Any one able to help?
Disconnect the power cable and the Battery from the Laptop. Then press and hold down the power button for 30-40 seconds and then release the power button. Connect the power cable and the battery and try to turn on the Laptop.
Oct 11, 2009 | HP Compaq Presario C306US Notebook
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Dell Dimension 2400 PC Desktop Logo
79 people viewed this question
Alun Cox
