SOURCE: lost program guide for rcr3273 rca universal remote need codestoo
Go to thompsontv.com/carc.html
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
SOURCE: Need codes for Sony Trinitron TV, with JER422
Sony uses A LOT of their Codes over and over again. So I would say the free route is grab a Learning Remote (JER422) hopefully does it. Ask who has a Sony TV and Copy their Codes and test it on yours. Some or all will work it's trial and error, But Sony is pretty good with that repeat the Codes thing! Good Luck!
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
