Question about Acer Aspire (AST180-US340B) PC Desktop
Sudden rebooting after 15 minutes of use
Yes, I can not get a consistent session on my Acer-Aspire AST 180UA 381B model desktop. After 10 to 15 minutes of use, the system shuts down and reboots automatically. It runs on Vista and detecting the problem is a mysteryl.
swoopd@yahoo.com
  • 36 Answers
Just a warning: It is never a good idea to tinker around inside your PC while plugged in! One slip could destroy any number of parts. MoBo's, expansion cards in most cases.
If your CPU has a fan mounted directly atop it make sure it is in good working order. And while your in there check your internal battery if you think it's close to replacement time!
Posted on Nov 13, 2008
  • 20 Answers
Check dust accumulation as mentioned earlier.
Also remove any hardware you recently installed since it started doing this. Products with incompatible drivers can cause the Operating System to crash. Systematically add the products after roughly 30 minutes to determine which product is affecting it.
Posted on Nov 08, 2008
  • 446 Answers
Chances are there is a accuulation of dust inside your computer, unplug your unit and simply dust off dirt, better yet if you have a grounded vacuum cleaner you cna use this to removed dust, other wise yu could damage your computer by static, check if your exhaust fan is working properly and the fan on the tp of your cpu works properly
cheers
    Genius:
  • 2,785 Answers
Plz check your power supply unit.
several things can be the cause:
Be careful when opening pc with power cord plugged in.
Dangerous voltage which can cause death or severe injuries exists inside pc. If you are not
familiar with handling electricity thye save way DO NOT OPEN THE PC!
1. Is the desktop free standing or in a cabinet or closet? (Overheating?)
1. check for accumulated dust inside the pc. (REMOVE POWER PLUG BEFORE OPENING)
2. check if all fans work.
3. reseat memory chips/cpu and plugs (REMOVE POWER PLUG BEFORE OPENING, ANTI STATIC MESURES MUST BE TAKEN TO PREVENT DAMAGE TO COMPONENTS)
Let me know...
Greetings, Matt
3 Suggested Answers
damnor01
  • 1179 Answers
SOURCE: Acer Aspire t690 Desktop Freezes
It is possible that your computer is overheating and is shutting down to prevent it from doing any harm to itself.
Make sure that all fans are clean, there must be no dust present as it hinders airflow!!!
Install as many fans as possible. Computer temps should be in the region of 30-40 degrees centigrade. To avoid CPU throttling, where the CPU slows down to prevent frying itself.
Please take the time to rate my expertise.
Thanks
Posted on Nov 01, 2010
gotgeek2
  • 565 Answers
SOURCE: Acer Aspire AST180-ED380M was working very
Sounds like the CPU is overheating. The usual cause is the CPU heatsink and fan need cleaning. Take the side cover off and have a look see. Also, it's possible that the heatsink may have come loose and isn't making good contact with the CPU. In either case you may need some CPU paste. Also check any case fans to make sure they are working.
After checking those things, suspect the power supply, memory, and possibly the hard drive.
Posted on Nov 27, 2010
Prinwhat port do I use to hook up printer to Aspire AST 180 UA 381B
Your printer should connect up to any USB port (small rectangular opening near where the monitor and keyboard plug in (same type of opening). If your printer is so old it has a cream colored cable and one end that has 25 pins sticking out of it, you will save money by just buying a new $30 printer. Anyhow, newer printers connect with a thinner cable like your mouse cable, is flat / rectangular on one end, and is kind of tall-igloo shaped on the other end.
If you go for the new printer, I used to hate Epson, but bought one December 2013, and it uses a lot less ink than my older Canon or HP printer. I bought one with a touch screen panel and it can print from my smart phone and all the PCs without connecting any wires. The one I bought was about $100.
Your PC has a very new wired connection (Gigabit LAN) for your home network; but unfortunately does not come with a built in wireless card. If you are also unfamiliar with the LAN cable, it is an RJ45 connector. Looks just like a phone cable, but 50% wider.
If this is unclear, feel free to add more detail or let me know what you need more clarification on.
All the best to you,
Kerry
Oct 21, 2013 | Acer Aspire (AST180-US340B) PC Desktop
My Acer X3400, monitor turns black
you ned to check your power savings settings. Lower or check to see if video pulls the unit out of standby mode.
Dec 24, 2012 | Acer Aspire X3400 PC Desktop
Can't get the side panel off my acer aspire ast 180-UD360A
Hi I was suppose to provide you the instruction however it would be better if you will see the images including steps on how to remove the side panel of your tower..This website will help you a lot ..
http://global-download.acer.com/Step5.aspx?Step1=Desktop&Step2=Aspire&Step3=Aspire%20T180&BC=Acer&Category=Document
Nov 17, 2011 | Acer Aspire™ T180 PC Desktop
Need a password for my acer t180, so that i can restore factory settings
It appears that someone has placed an Administrator password on the machine. To reset the Administrator password, unplug the desktop, open the side cover, remove the CMOS battery for 10 minutes. Then replace the battery, cover, plug the machine back in and reboot, hitting ALT+F10 at the same time to enter the recovery mode.
Mar 30, 2011 | Acer Aspire™ T180 PC Desktop
Can i add a sencond monitor to the acer aspire ast-180-ua380b
Depending what graphics is installed you will need a graphic card which supports dual output which is PCI express x16. Depending how good you need the graphics quality you can pick them up quite cheap. Cheers from Scott and plz vote
Jan 23, 2011 | Acer Aspire™ T180 PC Desktop
What graphic card that consist directx 10 which compatible with acer SA80?
The motherboard in this computer has an 8x AGP slot for a new video card. Most new video cards will have no problems with DirectX 10. Here is a typical card. Shop in your area or online for an 8x AGP card, check its specifications for DirectX 10 support, and you should find one with little problem.
Nov 30, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Acer Aspire AST180-ED380M was working very slow and locking up; did a system restore; then had to reinstall operating system (computer error message); now it seems to time out and reboot automatically,...
Nov 27, 2010 | Acer Aspire™ T180 PC Desktop
My Acer Aspire 180 ast power light flashes 4 times when I try to start it but it doesn't power up. I've unplugged the power and plugged it back. Can hear the fan start when I plug it back but it still...
Could be a faulty power supply or maybe motherboard problem.But I would open the case and clean the processor fan first as it could be a heat issue preventing start up.
Aug 01, 2009 | Acer Aspire™ T180 PC Desktop
Internet
try to change your network adapter
Dec 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire  (AST180-US340B) PC Desktop Logo
64 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
