Question about HP Business Inkjet 2200 Printer
Printout cuts off partway down the page
The printout is cutoff and continues on another page may be two instead of using up a single page. The last line may cut off the bottom part of the letters.
  • 6 more comments
  • garfield_spe Nov 21, 2008
    My printer prints parts of a page sometimes. It will continue on a second page, but might or might not use the entire 2nd page. It continues this pattern all the way through the print job. It may cut off the bottom half of the sentence like cutting the page with a scissors horizontally. Setting to A4 as opposed to letter does not help.
    prints only half page. Uses more sheets than it's supposed to.
    Any application that I print from has the same problem. Microsoft word, a web page, even a test page gets cut off half way down and it doesn't cut off evenly. The lower half of the sentence cuts off, and starts on the next sheet. Uses too many sheets for the job.
    Letter or A4, I get the same results. I have been using this printer for several years and this is a new one on me. I have had problems before but not like this. I set it to A4; Iset it to letter. No difference. This problem started out of the blue, and on 3 different computers.
    well on vista it finds the driver by itself and in the beginning since I started using vista everything was fine until recently.
  • garfield_spe Nov 22, 2008
    Ok, now I have a problem code. during all these trial and errors while the printer tries to initialize it gets a E: 0145-0001. Now I can't do anythig. What does that error code mean?
    E: 0145-0001 is on the printer screen. Should it clear it off of the printer screen?
    Not a fax machine.
    Sergeant:
  • 276 Answers
Printer needs servicing and resetting again.get the printer serviced internally  from some proper technician .then uninstall the printer drivers from your pc completely.and then reload the printer again.this will automatically detect the new settings and will work properly as before.
thanks.
Posted on Nov 22, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
re-install the printer driver!!
perform maintenance
is the same problem check the usb cable
    Genius:
  • 2,120 Answers
Scroll through the menus and set your fax parameters to AUTO REDUCTION
    Genius:
  • 1,239 Answers
HI THINK YOU HAVE PROBLEM WITH PAPER FEEDER
    • Paper tray/feeder - Most inkjet printers have a tray that you load the paper into. Some printers dispense with the standard tray for a feeder instead. The feeder typically snaps open at an angle on the back of the printer, allowing you to place paper in it. Feeders generally do not hold as much paper as a traditional paper tray.
    • Rollers - A set of rollers pull the paper in from the tray or feeder and advance the paper when the print head assembly is ready for another paSS.
The rollers move the paper through the printer.
    • Paper feed stepper motor - This stepper motor powers the rollers to move the paper in the exact increment needed to ensure a continuous image is printed.
  • Power supply - While earlier printers often had an external transformer, most printers sold today use a standard power supply that is incorporated into the printer itself.
  • ABHISHEK.C
    ABHISHEK.C Nov 22, 2008
    HAVE YOU SATISFIED WITH MY ANSWER
    Master:
  • 638 Answers
The error u get is because some of the drivers files are corrupted.uninstall the printer and reinstall it again to overcome the corrupt file problem
    Genius:
  • 1,605 Answers
Goto Hp.com and download the printer driver and associated software.
uninstall the software for the printer from control pnale>> add and remove program.
re-install the downloaded software.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=21433&prodTypeId=18972&prodSeriesId=27092&swLang=8&taskId=135&swEnvOID=228
Posted on Nov 21, 2008
  • Frank
    Frank Nov 21, 2008
    check make sure the setting is not LASERJET.
    When printing documents formatted for a LaserJet, pages in your
    document may get cropped, truncated or the content of one page
    may overflow to the next. Set the Emulate LaserJet Margins
    option in the printer driver.
    Brigadier General:
  • 6,966 Answers
Offhand, three (3) possibilities:
the paper size is set wrong in the Printer Setup of the application;
the paper size is set wrong in the Paper Type of the of the Printing Preferences of Printer Properties; or
the printer has a firmware/hardware fault.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • HP Master
  • 4,806 Answers
Re-intall the printers software, that will reset the printer to defaults, print a test page to verify page size
regards
  • 76 Answers
Can you share with us what application you are printing from. sounds like a page break was inserted into that document..the other thing you can do is to do a print preview, before printing, that will show you what it actually looks like. if that looks fine, then you'll need new printer drivers, which may be corrupted.
  • HP Master
  • 1,879 Answers
To nail-down what's causing the issue, print a test page from the computer (windows test page from the printer driver properties).
If the above test passes, check the page setup in your application.
Posted on Nov 17, 2008
  • HP Master
  • 19,396 Answers
Check on the printer settings, that the printer is set to print in the same format loaded in the tray.
Set the printer to print A4 and not letter format.
  • 2 more comments
  • Ginko
    Ginko Nov 21, 2008
    There is a reason if I insist.
    You are telling me "Setting to A4 as opposed to letter "
    That means it was set to letter.
    If you had letter settings before, as you told as, and you were using A4 pages , that is the problem.
    Letter is not just a generic term, is a paper size format longer than A4.
    Ensure that on the printer settings on LCD display you have A4 settings , and also ensure that at the same time the computer has A4 settings.
  • Ginko
    Ginko Nov 21, 2008
    Then you are reading my solutions.... Check both settings instead of refusing the solution at start, I am telling that on majority of print going over layout is because of paper format settings , either on the printer or on the computer settings.
    Otherwise, and you do not want to know this, it is a fault either with paper loader encoding, or with paper loading system, and does not cost less than $100 to fix (if you are lucky).
    Normally is just a setting problem concerning paper size, and you fix it by adjusting settings on computer and on printer.
    Letter format should not be used, unless you bought a paper called Letter and not A4.
  • Ginko
    Ginko Nov 21, 2008
    If this happens on three different computers, then is the printer, and drivers got nothing to do, printer drivers do not get faulty on three different computers at same time.
    Do the following:
    1 Check printer paper settings on printer LCD , not on the computer.
    Remove printer toners.
    Unplug printer power cable.
    Plug back printer and reinstall toner.
    Print a test page from the printer.
    If you still have the problem, it is probably a faulty paper loading system on the printer, call the service number listed on the user manual to get support.
  • Ginko
    Ginko Nov 22, 2008
    I told you the printer was faulty, the error code is not on service manual, if you call HP they will tell you the same.
What is the cause of characterized printout. When I printout a test page, it just prints all sort of digits and numerals in no chronological order. What is the cause, is it the motherboard??
A print test page does just that the printer will print every character that is in its memory, together with lines and if it has colours will also use the different colours
Oct 06, 2015 | Office Equipment & Supplies
I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Nov 05, 2012 | Office Equipment & Supplies
PRINTING ON PAGE IS VERY FADED AND SOME PARTS NOT PRINTING AT ALL
First, checkthat the USB cable is secure in both the printer and the computer and that theprinter is sitting on a flat surface. The printer may not work if it is tilted.
Next, run a printer check to make sure the printer is operational. To run aprinter check, turn off the printer and the computer and unplug the USB cable.Turn on the printer and press the Maintenance button. Use the down arrow buttonon the printer to highlight More Options on the display screen and press OK.Highlight Nozzle Check and press OK twice. If a page prints out, reinstall theR300 software on your computer.
Lines inPrintout
R300 mayproduce printouts with light horizontal lines that are not a part of theprintout. This is called banding and can have several causes. First, trycleaning the printer head to clear any clogged nozzles. To clean the printerhead on the R300, press the down arrow button to highlight More Options andpress OK. Use the arrow buttons to highlight Head Cleaning and press OK twice.The printer will take about 30 seconds to clean the print head, after which youshould run a printer check as described above. If the printout has gaps, pressthe STOP button to run the print head cleaning feature again. Once there are nogaps in the printout, press OK.
If the printout still has banding, open the Print window on your computer andclick on Properties. In the Properties window you can choose the print quality,speed and printer type. Select a higher print quality and a lower speed andmake sure the paper type matches the type you are using for the printout.
Finally, check that the ink cartridges are not empty or close to empty andreplace them as needed.
Faint Printout
If your printout looksfaint or faded when using the R300, try cleaning the print head. Next, replaceany ink cartridges that are old, low on ink or out of ink. Check that the papersetting on the computer matches the type of paper you are using for theprintout.
Another potential cause of faded printouts is incorrectly loaded paper. Sometypes of paper have a printable side that is whiter or shinier on one sidecompared to the other. The printable side of the paper needs to be loaded intothe printer face up.
Nov 20, 2010 | Epson Stylus Photo R300 InkJet Printer
When i am giving a single page printout it will printout another copy of blankpage
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
Nov 03, 2009 | HP Inkjet 1200dn Printer
NOT PRINTING LAST LINE ON PAGE
it could be that the lines on the spreadsheet arent bolded correctly or the spacing at the end of the document needs to be shortened. try to delete one space so that that line is brought up a line.
May 27, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
FONT TOO TINY
It's just the printout.
I use Internet Explorer.
May 30, 2008 | Canon PIXMA MP470 All-in-One Printer
What autofocus modes does the DiMAGE A200 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. Full Time AF that continues focusing without pressing the shutter-release button can be used in both AF modes.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What autofocus modes does the DiMAGE A2 employ?
AF single or AF continuous can be selected. In AF single mode, focus is calculated and set when the shutter-release button is pressed partway down. This mode is mainly useful for a stationary subject. In AF continuous mode, camera continues to focus on a moving subject even when the shutter-release button is pressed partway down. It is convenient to capture the moving subject. When setting spot focus point in AF continuous mode, subject tracking can be used. (Subject tracking can be turned on/off by the recording menu. ) When selecting the Spot Focus Point, Full Time AF can be used*. * Full Time AF can be turned on/off on the setup menu. * Sensors mounted on the grip and on the eyepiece detect when the camera is held.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
HP Business Inkjet 2200 Printer Logo
123 people viewed this question
Ben Johnson
