Question about Radio Communications
Rci2950keys up but no power gos out
Theres no dead key
  • 32 Answers
Check to make sure that the radio is on AM not FM or LSB or USB. There is Also a power control on the front of the radio turn it up half way and see if this might be your problem.If it still does not have any power out put,put the radio on usb or lsb make sure that your modulation is turned up and talk into the mike to see if you have any output.If you do have output on ssb mode the am regulator is most likely bad. ( Q 51 & Q 53) wich is located in the right hand side of the radio.
Posted on Nov 12, 2008
99 Chrys Twn&Cntry,trnd off&took out keys,locks &bells wnt crzy,Whn i stepped brke it stoppd, gos dead,pt key n,no turn ovr.No trns on.batt is gd,i mve thngs arnd by brke sdden it get pwr&trns ovrHELP
Look for a bad brake light switch or connection to it first. Many cars have interlocks to this switch to make sure brake is engaged at certain times, like starting car.
Would help if you wrote out complete English words and sentences to describe conditions in better detail.
Apr 02, 2015 | 1999 Chrysler Town & Country
All instrutments gages go dead until you disconnect battery then it gos back to normal
Without any further information, this problem hints of a security lockout. It also suggests a loose or corroded wire connector, possibly at the PCM, or the security module, if the security module is separate from the PCM.
Oct 11, 2014 | Electronics - Others
Setting timing marks
There should be marks on the flywheel.. The first mark should put the piston ABOUT 1.8 millimeters BEFORE top dead center and this is where you should set the timing! The second one should be top dead center (piston). Sounds like you have it waaaayyyy off!
May 23, 2014 | Suzuki Motorcycles
My tv wont turn on the green light flashes than gos red
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem...
Aug 11, 2011 | LG 32LG30 32 in. LCD HDTV
Hi My kids were playing with the xbox and it just went power off and wont turn on. The power supply has an orange light showing but the console is absolutely dead. Any suggestions? is there a fuse or...
sounds like your power supply his dead,but saying that the power light gos orange when the console his not powered up,so it must be your console
Feb 03, 2011 | Microsoft Xbox 360 Console
Does magellan lose its map if battery gos dead
hi etranchina,
no, you wont loose your maps if your battery goes dead. if you loose your maps, you have other issues. correct me if im wrong, but doesnt your 3250 have a map card. i would suggest backing up your maps on to your computer, if there still there...i always back up every gps i get.
are you concerned your battery is going dead, if so, why? that unit is know to develope a bad connection in the usb port (your power port)
let me know if you need further help
bill
Dec 31, 2010 | Magellan Maestro 3250 GPS
My 1996 ford e 150 5.o the oil pressure gage at cold start gos to low pressure as it warms it goes to normal but when i step on the gas the gage gos to dead low if i let go the gas the gage gos to normal....
Hello royamaral: My name is Roger and I will helps you. I would suspect you have a bad oi; pressure sensor. Should be located down by the oil filter. Just above the filter with a single wire going to it. Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Dec 21, 2010 | 1996 Ford Econoline
The DSI fault light gos on but I still get hot water on electric but the light still gos on after a half day. The gas will not ignite at all.
CLEAN THE CONNECTIONS AT THE CIRCUIT BOARD WITH A PENCIL ERASER. MAKE SURE U HAVE 12V POWER TO BOARD. IF AFTER CLEANING AND THERE IS POWER, BOARD IS BAD.
Dec 16, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Starting problem! '99 grand cherokee
The battery seems to be sending the wrong signals. get it replaced.
Feb 06, 2009 | 2005 Jeep Grand Cherokee
Radio Communications Logo
91 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
