I have a sony tv model # KDF-42WE655 manufactured in november of 2004. in 2006 just about every thing was replaced inside. worked fine until now, it just shut off on its own. it flashes red 6 times. I unpluged unit and repluged back in and turned unit on. green light flashed a few times but then goes back to the 6 red flashes. The tv does nothing, no sound or picture. please help.
  • 2 more comments
  • steveb515 Nov 08, 2008
    I guess this is not what I expected, I was hoping for the proper sulution as to what part I need to replace. I'm sure I can replace the part with a manual and schmatic after I know what is needed.
    I hope we can come up with a better solution. the 6 red flashes have to be code as to assist in what is going on.
    I guess this is not what I expected. I was hoing for a proper solution as to what part I need to replace. I'm sure I can replace the part with a manual and a schmatic after I know what part Is needed. I hope we can come up with a better solution. the 6 red flashes have to be a code as to assist in what is going on. I don't know what more I can tell you,the tv shut down by itself while I was napping. my roomate said it shut down by itself. he was present when this happened, he said it just shut down and screen went black and the 6 red flashes apeared.
    isn't there a common solution to this I'm sure other people have comented on this. if its a solder problem, what is the main circuit board failing with this issue. usually if there is a solder problem, you just replace the board.
    I'v heard it could be the g1 board and also heard it could be thermal fuse. I was hoping you could point me to the part I need.
    I have also heard about the over current over voltage, that this may be the possible cause.
    this a-b board is that 1 or 2 boards and by any chance do you know the part # and the location of these boards
  • 320 Answers
DISREGARD ALL PREVIOUS POSTS!!! 6 blinks on this set has NOTHING TO DO WITH HORIZONTAL STOP!!! You likely have an open thermal fuse. Please get in touch wtih me directly and I will walk you thought this. Thanks!
Posted on Nov 08, 2008
  • Any Guy
    Any Guy Nov 09, 2008
    Steve I have sent you a copy of the bulletin and step by step instructions for repairing your TV. Let me know if I can be of further service.
  • Any Guy
    Just wanted to see if you received the email with instructions and your bulletin
  • 10,594 Answers
6 time flash error means Low B -No "DD 6V " output (G1 board)
G1 board is located as shown in below picture.
Its part number is as follows..
A-1060-177-A G1 BOARD, COMPLETE
Need further help, please let me know.
Thank you.
  • 2,334 Answers
If you download the service manual and check the G1 board schematic diagram on page # 57, look for D1630. That diode is the 6 volts rectifier and according to the 6 blinks, it means that the voltage might be missing or low, if the voltage is low you will have to measure C1677 for low dielectric/capacitance or replace it.
If you decide to replace the entire G1 assembly, you can find it here.
    Master:
    Sergeant:
  • 449 Answers
Hi
replaced the power supply!!!
    Master:
  • 505 Answers
First make sure all the cable at the back of the TV is connected properly.
The problem you referred means that the TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
From description, the Digital Processing Board can be cause for the problem as there is no video.
However all the following parts can be involved.
Parts involved can be
LCD Controller
Contact some local tech shop or geeksquad to get the unit repaired.
Thanks
  • 749 Answers
Just a suggestion, I worked on Sony tv's for 8 yers and one thing I know about them. The parts are sold in kits, this is done so that every weakened part in the circuit is replaced along with the defective one. Most times , if you omit the weakened parts, the set will fail.
I am not trying to persuade you not to fix it , just take a closer look at your options.
    Genius:
  • 1,550 Answers
LOW B OCP/OVP (Overcurrent/over voltage).
Possible causes - +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards).
  • 435 Answers
Take a look at this web page:
http://www.iwaynet.net/~nesda/SonyBlink.html
It is a good tool for getting some idea of Sony sets.
You say your light stays on and is blinking, then look at the variouscomments for that number of blinks on that above mentioned site.
  • Narmada Anand
    Narmada Anand Nov 08, 2008
    The most common problem we see with a 6 blink is a bad sensor.
  • 13,433 Answers
Timer/Standby Indicator Blinking
SIX Blinks---
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
heres the service manual http://www.eserviceinfo.com/downloadsm/31578/Sony_KDF-42WE655.html
Its in 9 parts and requires winrar, may be difficult to download.
  • Ekse Nov 08, 2008
    You have been given the diagnosis, and a service manual. Together with these two things you should be albe to attempt fixing the set if you have the experience and knowledge.
    let me know if you want the service manual, I downloaded it and its now in a single file, Il send it to you if you want.
  • Ekse Nov 08, 2008
    Brigadier General:
  • 6,966 Answers
Initially, the 6 blinks normally would indicate "no Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis function immediately. This would mean that the unit has to be opened up for a look and see meaning it require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back if you are considering a DIY, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 08, 2008
    I am assuming then that you would want to perform the repairs yourself and that are familiar with the workings internally.. Initially, pls check the:
    • low B+;
    • thermal fuse (the optical block has to be unseated);
    • fan;
    • ballast.
    Would appreciate any update (or even the lack of it).
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bright galaxy like dots on KDF42WE655 why?
Light engine is bad. Contact Sony they have been replacing these due to a class action law suit.
Mar 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kdf-42we655 tv randomly turns off and comes right back on??????
That may be the lamp. Replace the lamp and see if that solves it. It's usually the cheapest thing you can do to first troubleshoot it without paying someone to come out there to fix it.
Feb 03, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Audio stopped working with my sony kdf-42we655 tv.
Reset the Audio back to factory setting.Should work, some wrong setting in ur setting.
Jan 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have Sony TV model KDF-42WE655 which stopped working. No display and when powered on, the green light comes on and blinks approx 50 times and turn red (blinking red). How and what do I need to buy to fix...
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv will shut off and red light will flash 3 times
If its Sony KDF-42WE655 TV that goes to standby and LED blinks 3 times then check Lamp Door that seems not fixed properly.
That happens when lamp replaced in TV.
If its different model number TV, let me know exact model number.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Jul 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How to change a light bulb on a sony KDF-42WE655
Please download user manual of KDF-42WE655 from Sony Support and go to page 17, there described how to replace lamp in this TV.
Dec 07, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-42WE655 Replacement Lamp
First thing i would ask is where is the smell coming from?
Jan 26, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
