Question about Frigidaire FRT21P5A Top Freezer Refrigerator
Fridge & Freezer not getting cold enough
Thanks for the help! The fridge was in defrost. He switched it back and the fans came on. However there seems to still be a problem. The fridge and freezer still are not getting as cold as they should be. It has been just about 42 hours since we switched it out of defrost. The freezer's temp is ranging between 20-28 degrees. The fridge is ranging from 40-48 degrees. It isn't getting any colder then that. I have no idea what else could be the problem. We had taken the back panel off in the freezer and there was ice on the coils. I had read here to take a blow dryer to it and get the ice off. Which we did, but that apparently wasn't the problem. Any ideas? If not, that is ok. You have been a great help anyways! :)
  • Patty Welshons Oct 29, 2006
    Catriver:
    Evaporater completely frozen over. Ice all over it. This fridge was my brothers and he gave it to me when he left to go to Oregon 3+ years ago. He doesn't have any of the warranty information on it. What should we do? Call a professional? Does it cost alot to fix the evaporater?
    Thanks for your help!
    Do you know where I would find those parts? Also, My husband wanted me to mention to you that the Condenser coils at the bottom were not warm. They were room tempature. Does that make a difference? Thank you so much for your help!
    President:
  • 878 Answers
Welshons, Take a look at the picture Im posting. Did your evaporator look like it? If so your system may be restricted. This is a pretty common problem in Frigidaire top mounts. The good news is that it would be covered under warranty if it is not over 5 years old. As long as your condensor fan is running and the condensor is clean, evaporator not frosted up and evap fan running. I would think that you have a weak compressor or a restriction. Catriver...post back.
Posted on Oct 20, 2006
  • 1 more comment
  • Ron Marek
    Ron Marek Oct 20, 2006
    Weak compressor and restriction.
  • Ron Marek
    Ron Marek Oct 29, 2006
    OK, if it was frozen all over again you have a defrost problem. It's either going to be the defrost timer sticking or the bi-metal open and will not go into defrost. I would change both of them. This is not a hard job. The defrost timer sits in the control panel and is just a plug in. All you have to do is remove the screws that hold the control board up and the screws that hold the defrost timer in and plug the new one in. The bi-metal sits on the evaporator. You can splice the new one in with wire nuts and seal the nuts with silicone. Your part numbers are 5303918202 for the bi-metal (defrost thermostat) and 215846606 for the defrost timer. Catriver...post back.
  • Ron Marek
    Bad bi-metal
SOURCE:
I have a Beko frost free fridge freezer kept in a garage that has all of a sudden just stopped working. I noticed that the bread I'd put in the freezer hadn't frozen and then noticed that the fan had...
If the fan has failed or intermittent, the freezer wont freeze the food properly but usually you get a mountain of ice build up at the back of the freezer. This ice jams and stops the fan from turning. Alternatively, there could be a defrost problem. Unless it is a fully electronic defrost machine, there is usually a little timer on the back of the fridge to force a defrost after a certain time. The fridge will turn off, the defrost heater operates to melt the ice and then usually with 20 to 45 minutes, the defrost timer will "click" back on and start the fridge running again. If the timer is sticking, the fridge may stay on its defrost cycle and never start again, thus, it doesn't get cold. If you find the defrost timer, have a close look for a little shaft or slotted screw type stud sticking out of the middle of it. A slight turn of this and you should hear it clicking around. When you hear a loud click, that is either the start or end of the defrost cycle. If you have a full electronic defrost system, it may be a failed board, heater, thermostat or defrost safety fuse.
Jan 05, 2015 | Refrigerators
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
Whirlpool side by side Fridge Freezer S20BRBB20
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Apr 30, 2010 | Whirlpool GC5NHAXSQ
GE Monogram Built In Fridge-freezer is not cold enough, but ice is ok...refrigerator is too cold no matter the setting. Someone suggested vacuuming filter above the fridge. Would this work?
Feb 23, 2010 | Refrigerators
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
Westinghouse Fridge Problem
Is the fan in the freezer running? You should be able to hear it. If not, that is your problem. Check the door light/fan switch or check if the fan has power to it when you press the door switch in by hand. If fan is running, you could have a defrost problem. The defrost timer or the defrost heater could be faulty.
Nov 04, 2007 | Refrigerators
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
1,481 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
