Question about Microwave Ovens
Just got my new GE Cafe microwave. Set it on the table, plugged it in and it worked fine. Hung it on the brackets, plugged it in and it does not work. I do have power to the outlet. I have tested it repeatly. When I remove the microwave from the wall and set it back on the table it works. I am an Electrician so I know if I have power or not.
Throw out side near garbage
Posted on Nov 08, 2008
My GE Cafe microwave touch pad will not work. Everything seems to be working. It is a built in , above the stove 2008 model.
Here is the information page on the repair of GE Cafe microwave ovens.
http://www.microwavecontrol.com/jvm2070.htm
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | GE Microwave Ovens
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
Where can i get the ge cafe microwave handle cover?
You can find links to helpful exploded view diagrams and order parts here.
Dec 27, 2012 | GE Cafe Series CVM2072SMSS 2.0 cu. ft....
I have a ge cafe microwave...the cook and defrost functions do not heat up but the melt function still works?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 07, 2011 | GE Microwave Ovens
Having difficulty getting old spacemaker oven out in order to install new.
There are two screws coming into the top front accessed inside the cabinet it is mounted to. the rear of the unit is hung on clips on the bracket screwed to the wall behind it. Take out the two screws ( sometimes hidden under paint or shelf liner) and have someone hold the front up. Then push up on the whole oven and pull it out towards you. ( get help it is kind of heavy). dont forget to unplug it, and feed the cord down as you pull the microwave out. sometimes you have to pull hard, as the pins on the bracket get bent during installation.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Want to remove microwave to install new one.
there are a few ways these can be hung/removed , one is bolting it to the cabinets above it , check for bolts inside the cabinet.
the other way is the bracket in the back of the unit may have a hook or pin around it for a release.
they hide these behind the grill covers on the top or the bottom as well.
let me know how it works out.
Phil
Apr 15, 2009 | GE Spacemaker 1.5 Cu. Ft. Over-the-Range...
Installation of GE Microwave Oven
We have changed out a GE for another same brand, newer model. You will need two people to make the change-one of the two must be strong enough to support the unit after you remove the 3 bolts that hold it into the cabinet above. You will see these screws in the bottom shelf of the cabinet above your unit. A driver drill w/ the socket attachment to fit these "screws" would make it go faster. You'll need a step stool or a step ladder to get above the unit. There is a power cord that plugs into an outlet-make sure you have unplugged this before starting.While one is supporting the unit, the other is unscrewing the three bolts, When screws are out, the person on the ladder should come down and help w/ the unit removal. The unit is tipped forward to release it from the wall, as it is hooked into a bracket affixed to the wall. When you tip it forward, both of you should be prepared to lift it off the bracket. It helps to have the way cleared and a table or countertop ready on which to set it. BTW, My microwave installer did not use the flange provided to seal the vent around the cutout in the lower shelf of the upper cabinet. Removing ours, I can see why, there is no way to get the unit lined up w/ the flange and the duct and still tip it into the provided cut out. We bought metal sticky duct tape to seal it, and used the opportunity to reseal the above cut outs as well. I think some cabinets are constructed around the microwave installation, and if so, you could use the existing flange set up. When you are ready to put in the new one, do it in reverse, but schedule some clean up time in between, the grease finds a way of eluding all systems and you'll want to 409 it before putting in your new one. If this is too mu8ch for you, ask an installer or a neighbor to help-it doesn't require an electrician. You might want to ok into what GE is doing these days so your aren't dissappointed w/ the new unit after such a successful run with your first purchase.
Jul 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
