Question about Radio Communications
Rci2950 older 2950 work great for years now keys up but no power go out
YOU HAD IT LONG ENOUGH GO ON
Posted on Nov 15, 2008
Some of the keys are not working, computer was not being used for several months and prior to being stored everything worked great. Can anyone help please?
If the year was like, 1998 or something older, it might be the beginning of the end for the computer. Otherwise... i don't know what would be if it was stored correctly
Aug 21, 2013 | Gateway EC1458U Notebook, 1.30GHz Intel...
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
Looking for parts for galaxy saturn turbo push button key pad and power meter
contact me i had some extra 2950 parts. and if just need the rubber buttons pad. there interchangable. and we can order you the pwr meter from ranger.
Dec 14, 2009 | Radio Communications
I have a GE model No. BTN 748A100A1 (central air outside unit). Serial number 40564128. When was it made? What is its efficiency? It now handles #1950 sq. ft. Cab it handle 2950 sq ft when I remodel?
GE stopped making AC units probably 20 years ago. The same unit will not handle an additional 1000 sq. ft. I believe it is a four ton unit and about a 6 SEER rating which is way down on the efficency scale. You will need a 5 ton system to handle 2950 sq. ft. The average SEER rating now is 13.5.
Oct 07, 2009 | GE Heating & Cooling
My powerdege 2950 dell server doesn't display anything on screen and doesn't respond to mouce or keyboard keys I've tried to shut it down fremoving the power supply for more than 2 hours and when I start...
g_cic14
If the server is not posting then most likely you are having a hardware problem. If you let me know the light that you see and where they are I can tell you what is wrong.
Issken
Sep 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Older Cr 1604, powers up but no output, suddenly after gig.
The power supply is located in that area on one side. It is possible that one of the output op-amp ICs has failed. There are a number of 4558 ICs used as output buffers for this unit. Without seeing the unit and testing parts of it, I can't say for sure. These are not the easiest to work on as they are really compact. Where are you located? I may be able to suggest a service center in your area. The repair cost should not be too bad. The parts are cheap and readily available. Please update this with your location. Thanks, Dan
Jun 06, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
Apr 04, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
IP IOS Command not working with switch
you want to give IPs to your VLANs and also make physical interfaces members of a VLAN instead of giving IPs to physical interfaces
Mar 05, 2009 | Cisco Catalyst 2960 8-Port Ethernet Switch...
Radio Communications Logo
137 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
