1993 Saturn SL Logo
Anonymous Posted on Nov 08, 2008
Need the code for the anti theft device for a 92 saturn
My wife took the battery off the car, and had it charge on a local auto parts store. when she installed the battery back on there was a short and on the dashbord appeared a light reading" anti lock" i'm told the anti theft device was activated. because it was not turn off to begin with.
  • Anonymous Mar 18, 2014
    the car lot turned it off they said and I want to turn it on
Anonymous
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Nov 26, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
156347
Points
684
Not at all, the alrm will not cause the anitlock light to come on, try resetting the computer again by taking the positive battery cable off for 10 mins, if this does not work, then you definatly have a problem with the anti lock and the computer may have been over loaded so it did not reconize it until the computer was cleared when she took the battery out.
I have a saturn 2002 L200 the security light keeps tripping as i turn it on and . wont start keeps draining battery. how can i fix this
there are several TSB's pertaining to the anti-theft system. the best option is to see what part of the anti-theft system is not working. There should be codes in the theft module. you will need a high end scan tool to get these. anything less than $1,500 will not get these codes. You will likely have to get a GM dealer or a good independent shop to help you with this. Once the problem is resolved the anti theft can be relearned if necessary and you should be fine until the next thing goes wrong...
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2answers
How do deactivate anti theft system on my 2000 pontiac montana
Contact local GM dealer to deactivate or repair the problem. That will be the quickest way to get you going.
I need to know what battery I need for a 2003 matrix xrs?
The correct battery size for your vehicle is the "35" case size. Try to get a battery that has at least 600 CCA (Cold Cranking Amps) with a three-year "free exchange" period. Your local auto supply stores should have this battery for about 90 bucks, give or take. Always match the original battery to the new one (note polarity position, for example). Some vehicles assembled in Canada are given optional batteries (usually slightly larger in size) for handling extreme cold conditions.
If possible, install a memory-saver before disconnecting the old battery to preserve radio presets (and anti-theft codes) as well as ECU data.
After installing the new battery, have the charging system checked to ensure that the alternator is charging properly.
I hope this helps.
Have a great day !!!
2answers
Lights were left on killed battery then anti-theft light came on and now the car wont start do we need to reset the compter?
should be able to call the dearlership to get a code to reset the antitheft system unless u know it
2answers
1997 olds cutlass supreme The security light is
Open ,and shut the doors,and the hood,and the trunk,then set the anti-theft,leave it set for 5 minutes,then disarm the anti-theft,and then try and start the vehicle.
Vue 2003 saturn
try locking and unlocking the car with the remote, maybe a anti-theft issue?? what do you mean" tries to start?" either the engine turns over or it doesnt. if it turns over, but wont run, thats another story.
1helpful
2000 Saturn LS1 dashboard battery lite
the alternator has a circuit in it that illuminates the battery light on the dash.that circuit is most likely at fault but because the battery went dead once i would think your alternator is just about at the end of it's useful life.
4helpful
2answers
Anti theft light blinking on stock radio in 92 honda accord
You must go through your local honda dealer, (usually parts department) give them the numbers off the labels on the radio, along with the VIN number of the car. may have to prove ownership. They can call Honda and get that information for you. Process is alot easier if you someone that works in the parts department, if not the honda parts department, then another parts department at another car dealer.
1helpful
2answers
Car radio
This happened to me. It usually happens when the mechanic takes out your battery. It resets the radio, I think it might have something to do with the anti-theft system.
I wouldn't take the car to the dealer to get the radio code, but to a local auto repair shop. When I took my car to the dealer to have them remove the radio to get the "four digit code" they wanted to charge me $100. So, I went to a local shop, and they removed the radio, punched in the code, FREE of charge.
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
