Question about Brother MFC-440CN InkJet Printer
Replaced ink cartridge printer continues to say no cartridge
Mfc 440
printer indicated that the black cartridge was empty. replaced it but the printer still says black is empty. replaced it with another cartridge and it still says it's empty.
  • carmonarj555 Dec 10, 2008
    cyan, ad yellow don`t come out wen printing whith color
  • 26 Answers
The way the MFC-440 (and lots of other inkjets) detect ink level is by shining a tiny light through a window on each cartridge. If the light passes through then the printer assumes the cartridge is empty. Take out the suspect cartridge and be careful not to tip it forward or backward i.e. keep it in the same orientation as when it comes out of the printer. Now look at the little plastic window that is on the end of the printer. Does it look clear or does it look black/blue/red/yellow? If it looks clear then your new cartridge is not really new at all. It is empty. Take it back and get another.
Posted on Sep 29, 2014
  • 1,257 Answers
We got disconnected.let me know if the article that you followed was able to resolve the issue or not.
contact me at my profile
Posted on Nov 08, 2008
  • 446 Answers
You need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Indicates black ink empty when its not.
Try removing the cartridge and shaking it. Brother printers use an optical ink monitor with a float inside the cartridge. The float can get stuck sometimes and indicate incorrect ink level.
But keep in mind that printers often indicate 'empty' (on purpose) while there is still bit of ink left in the cartridge, to prevent running out of ink during printing. If shaking doesn't help, replace the cartridge.
Aug 25, 2014 | Brother MultiFunction Center MFC-440CN...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Black ink empty
hello, please see this e-book to assist you.
Sep 21, 2009 | Brother MFC 240C All-In-One InkJet Printer
Ink replacement
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Feb 18, 2009 | Brother MFC-440CN InkJet Printer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother MultiFunction Center MFC-440CN...
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-440CN InkJet Printer Logo
405 people viewed this question
James Cagle
James Cagle
Jim Keysor
