Question about Akai LCT2715 27 in. LCD Television
Power Supply Buzz
TV was given to me dead. I removed and recapped the 200W power supply using good 105 degree C capacitors. Most of the old caps were shot. TV now works fine. Unfortunately, it has a loud buzzing that appears to be coming from one (maybe both) PQ3220-1000C transformers.
Would you have an idea of what other component(s) might still be defective? I see no other visible damage to the power supply.
Thanks.
  • 1 more comment
  • gehdiving Nov 13, 2008
    Thanks for your response.
    Yes, all caps were replaced with the same rating, with the exception of two 470uf 25v, and two 470uf 16v caps. They were replaced with four 470uf 35v caps as 25v and 16v were not available from my supplier. My understanding is that this should not be a problem??
    Polarity of all the caps is confirmed as correct.
    There were also two bad 1000uf 16v caps on the TV main board next to the power connector. They were replaced with 1000uf 35v caps.
    I have seen numerous reports on the web of these power supplies buzzing in brand new sets. Most returned under warrenty.
    Interesting that you have never run into the buzzing problem.I recapped another of these same power supplies about a year ago and that one buzzed too. That set went in the trash can because of a bad display and no sound.
    If you think the four higher voltage caps that I used are a problem, I can track down ones with the lower rating and change them. Let me know what you think.
    Thanks again.
  • gehdiving Nov 14, 2008
    Unfortunately, I don't know whether the supply buzzed prior to the recap as the set was given to me dead.
    Any suggestions as to what you consider good quality capacitors and where to obtain them?
    Thanks.
    Thanks. I'll give some thought to recapping it again.
  • 30 Answers
Did you use the same as original replacement capacitors? I have repaired many of these power supplies for others and never had an issue. It is possible that the failing capacitors could have caused more damage to the power supply but I have never seen it in over 50 repaired AKAI power supplies. Also, make sure you replaced the capacitors with the proper polarity.
Posted on Nov 12, 2008
  • Vernon Gibson
    Vernon Gibson Nov 13, 2008
    While this shouldn't be a problem and I have even used higher rated caps in the past when I did not have an exact replacement it could not hurt if you can to replace those with exact matched caps. I also suggest using high quality capacitors as I have seen issues similar to this arise by using low grade components. If the power supply did not buzz prior to the original capacitor repair I would think that it may have been a result of the cap replacement or damage sustained from the power fluctuation that the failing caps would have caused. If it did buzz prior to the repair I would suspect something on the AC side of the board that is causing this.
  • Vernon Gibson
    Vernon Gibson Nov 14, 2008
    Nichicon is what I buy about 90% of the time. From what I have seen they are a pretty good manufacturer for quality components and I have never had anything fail that I have used them in. Most capacitor manufacturers have a Premium line and they have a bottom dollar line... In some cases the old adage "you get what you pay for" is true. But, Nichicon tend to be reasonably priced and they are from what I have been able to determine good quality.
    I buy a lot of parts from Digi-key.com as they have quick shipping and good prices for most parts. Their site is not the easiest to navigate but they have pretty much anything you will need.
Tv whines and turns on and off. good picture everything works just makes the buzzing sound and turns off and on by itself. I think replace power supply. any input would be great thanks.
It is more than likely a capacitor or two on the power supply. I would replace the power supply or the capacitors on the PSU board if you are comfortable with a soldering iron, flux and desoldering braid/ vacuum pump.
When I replace the caps I always get a slightly higher voltage and ensure I get 105° rated caps. If possible find some low ripple capacitors. Typically if they are 16V 1000uf I will replace with 25V 1000uf 105°.
Dec 14, 2015 | Televison & Video
When I turn My Samsung LCd On the power button flshes a light and an audible tone plays the screen will light up then go off immediately
Samsung model? It may be detecting the shorted circuits in the inverter board or it may have bad power supply due to bad caps.
See excample of failed SAMSUNG TV here (look at LNXXXXX): http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 21, 2011 | Vizio VO47L 47 in. LCD TV
Why does it take so long for the tv to come on ?
This is a good case of failing capacitors. You will need an ESR meter to find the bad ones. Start with the power supply. If you must replace these capacitors, use same or higher voltage, The Mfs must be of equal value. Be sure you use a high temperature capacitor.The 105 degree caps are ideal! Thanks for asking and show a few hands of support!
Feb 20, 2011 | Televison & Video
Dead tv seems like theres no power but there is
If you can locate the power supply, you will find the problem here. You will need to purchase an ESR meter to check and replace the capacitors. Be sure to use the same value capacitors and be sure to use high temperature caps at 105 degrees. Thanks for asking and show a few hands of support!
Feb 18, 2011 | Protron PLTV-32 Television
Red lights is on and when I go to turn on the TV the green light only stays on for 1 second.
Your external power supply is the culprit. The small box that is connected the outlet plug is bad. The TV itself is fine! The external box has a bad capacitor inside. You will find a 16 volt 1000MF capacitor at 105 degrees that is bad and next to that one is a 25 volt 1000MF at 105 degrees, replace as well! Show this info to your TV tech or hobbiest and repairs will be at hand. Thanks for asking and good luck!
Jun 30, 2010 | Proscan 19LA25Q 19 in. LCD Television
Tv worked last night. This morning, no picture, no sound but ambilight works as normal...any clue??
this could be caused by vented capacitors in power supply..........look for domed tops on the electrolytics(small can shaped devices)on power supply board. These are bad and need replacing. 1000uf 10v.
Replace with high-temp(105 degrees C) electrolytic cap.
I use 25v or greater. Good success........meder'sTV
Apr 01, 2010 | Philips 42PFL7432D 42 in. LCD Television
No display flashing power button
savato321, Most black screen lcd monitor owners don't have the smarts to open up their monitors to do a VISUAL inspection of the "switch-mode-power-supply/inverter supply!!!! You're good. Now you will need to know some stuff about electrolytic filter capacitors! First, the "uf" or "UF" means micro-farad! It is just a rating given to express the storage capacity of the device. Next is the voltage rating. A 16v rating means that the capacitor should never be placed in a circuit where the voltage will exceed 10 to 12 volts DC. Your 820 uf cap rated at 25volts will most likely be in a 12 to 18volt dc circuit. Now for temperature rating. All caps have a maximum temp rating. Most clock radios, stereos, will use 85 degree centegrade rated caps. Printers,PCs,monitors, will use 105 degree C rated capacitors. Never replace with lower specification units! You can GO up but never DOWN. If 1000uf 25v is all you can get it's OK. If you can get 820uf 35v units and they are not too big and they will fit on the board sure you can use them. I would stick with the OEM design voltage rating. Electrolytic CAPS are polarized!! You must replace them + to + and - to -!!! If you screw -up they will blow-up!! The wire lead closest to the printed STRIPE on the cap will be the negative and the unmarked terminal will be the positive. If you visit www.ccl-la.com/badcaps.htm you will get more info on recapping your SMPS. You can also watch some DIY videos at YOUTUBE for "lcd monitor repair" that might be helpful. Also visually inspect the SMPS/inverter printed circuit board for "COLD" FROSTY looking solder joints. They should all have near mirror finish to them. Let us know the name of the BAD CAPS you remove from your unit. You may even want to document with pics with a digital camera what you find. Well, good luck guy
Jan 17, 2010 | Samsung SyncMaster 932B LCD Monitor
Monitor turned off and now will not restart (Power light flashing rapidly)
If your LG L204WT will not power up all of a sudden, or takes long to power up, or dies after a while and it has not been exposed to lightning damage then in all likelihood the Electrolytic capacitors in its power supply has started to fail.
Unplug the unit from mains. To open it up, remove the 4 philips screws at the back. Then starting at the bottom corner use a small flat screw driver to wedge the front bezel loose. After removing the bezel the rear casing will also come off the panel. The circuitry case is taped to the panel with silver tape. Loosen the tape, lift the power supply. Carefully unplug the two sets of backlight cables, and the front panel controls to completely remove the circuitry case. Now remove the 4 screws holding the power board and then replace the following capacitors:
You can order caps from most electronic component stores.
You will need to replace:
C105: Electrolytic Cap, 47uF 50V 105 degrees C
C106: Electrolytic Cap, 1uF 50V 105 degrees C
C202,C206: Electrolytic Cap, 680uF 25V 105 degrees C
C203,C204, C205: Electrolytic Cap, 1000uF 25V 105 degrees C
You can always use a HIGHER voltage and a slightly HIGHER uF, and HIGHER temp rating but never lower.
Make 100% sure to observe the polarity when replacing the caps. Electrolytic caps have a clear negative marking stripe on the side coinciding with a black mark on the board.
Nov 27, 2007 | LG L204WT LCD Monitor
Akai LCT2715 27 in. LCD Television Logo
641 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
