Question about IBM ThinkPad T40 2373 Notebook
Laptop problem my laptop switches off when i lift it up
This is a known issue with the T40 series. I have the same problem. It's a result of a manufacturing defect introduced through a new soldering process Lenovo used on this series. Basically, they baked the motherboard in an oven instead of soldering the components on one by one. This resulted in many of the graphics chips not fully connecting. After normal use, a corner can pop up, causing the screen to go blank if you move, lift or jostle the laptop.
As far as I know, Lenovo doesn't offer any fixes for this. If you wish to risk it, you could try soldering the loose corner yourself. Some people found a wedge works well. I stuff carboard between my keyboard and the chip to keep it down. Other people hve been known to use post-it notes.
Posted on Nov 24, 2008
Wifi switch stuck on off
unscrew the screws at the bottom of the laptop, slightly lift the upper bezel of your laptop just under the wifi switch and try to move the switch,should work,but dont be too harsh trying to lift the bezel,gently place ure thumb nail or get some old expired credit card or anything of the sort that can slide between the two bezels .
Oct 02, 2012 | HP Compaq Presario F730US Notebook
How to take apat laptop toshiba satellite p 305-s8822
first face the laptop downwards and remove the battery hard disk and memory from its compartment next remove all the screw the face the laptop up wards the near monitor above the key board you will see a plastic plate with power switch and all lift one side as it is a plastic locl and lift it upward fully also note there might be connector to the plate be careful while using the force the remove the cable to the lcd then remove the hinges screws the tilt the keyboard and remove the connector then remove all the connector you can see below the keybaord which is connected to the motherboard then tilt the laptop remove the back cover then remove all the connectors from the motherboard unscrew all the screws and also note to remove the heat sink then lift the motherboard to fix it back do it vice versa
Oct 01, 2011 | Toshiba Computers & Internet
My laptop is not being booted
remove the power from the laptop face the lap top down and renove the battery then remove the screw just above the battery and lift open the cover there you will see the memory in the side of the memory you ill see see two metat strig pull it sideways and the mamory will lift up then pull the memory sideways and remove it from the lap top clean the edge of the memory with a clean cloth tthen replace the momory into the slot and press them down till the memory stays then fix your battery and switch on the laptop
Jul 03, 2011 | Lenovo Y560 - 15.6 - 500GB - Gray Hard...
Hi, I have compaq 620 laptop. The display has gone blank suddenly. It is powering on as wireless and power lights are glowing. Also, i can hear spinning of hardisk. Please guide
Jul 03, 2011 | Computers & Internet
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
Hope this helps.
Apr 05, 2011 | Computers & Internet
I lift the notebook from the left hand corner and laptop switches off
visit a computer store to fix the issue...
other option is dont lift the laptop at all...
Dec 10, 2009 | Samsung V20 XVC 2400 Notebook
Electrical interference on a DELL laptop.
Try a ground lift on the audio desk Im guessin it phase issue
ground lift is a small grey or orange 2 prong mail and 3 prong female any hardware store will have them...FYI
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
To open acer laptop
slide the little switch across at the front of laptop and lift.
Sep 08, 2008 | Computers & Internet
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
66 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
