Kef coda s subwoofer
Currently my subwoofer isn't working anymore. I checked the fuse, and it's still good. still no power....any clues? thanks!!
  • blondebabii1 Nov 23, 2008
    the switch is turned on and its plugged in but i get no power i havent had it very long! i dont know what is wrong. any one have any idea?
5 Suggested Answers
brainyass
  • 242 Answers
SOURCE: Replacement KEF Coda III TWEETER Type SP1087
Go here and find a nice substitute. Many to choose from and it may be better to purchase a pair of them rather than have mis-matched ones. They should be inexpensive enough for you, as low as $2 up to $480. You just need the size of the mounting hole to find a replacement though.
http://www.parts-express.com/speakers.cfm
Posted on Nov 21, 2008
  • 75 Answers
SOURCE: kef subwoofer kht 2005:2
check for the connection og the main wire is cut.. or check the supply..
Posted on Dec 08, 2008
SOURCE: KEF Subwoofer AV1 and KEF Activator. Need specifications
Unit is now 12 years old min. and no longer state of the art.... i offer $400
Posted on Jan 28, 2009
  • 222 Answers
SOURCE: I just would like to change one of broken speakers
try their website
Posted on Jun 08, 2010
Kef htb2 subwoofer not working plug fuse ok sub fuse ok is there an internal fuse
If you have external fuse there will be none internally. Chances are you have blown the amp if power is confirmed to be getting into the unit and there is no sound.
Sep 16, 2017 | KEF Audio Players & Recorders
Wiring
You need to trace the wiring back to your amplifier, Whatever is on the positive (red) on the amp you should use on the speakers.
Mar 05, 2012 | KEF Audio Coda 9 Speaker
KEF Q 35 speaker problem
Care to elaborate? We need some clues.
Jun 13, 2010 | KEF Audio 35B Speaker
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
KEF Subwoofer PSW2010 (KHT2005.2) - No power
chik power sours first
thaen chik transformer inside
u will see it burned if so chang it
Aug 18, 2009 | KEF Audio KHT 2005.2 System
Nov 21, 2008 | KEF Audio Model Three Main / Stereo...
Subwoofer clicking noise
Hi I am afraid it sounds like exactly the same problem I had, Namely the PSU(power suplly unit) is failing, This is a common fault (by reading loads of forums) I contacted KEF today about mine and they say the probably wont be able to source any more spares(due to so many having thuis problem no doubt) So I would suggest contacting the people you bought it from,Under the consumer protection act you should expect an electrical item to "Last a reasonable amount of time" .Mine is 3 years old and I do not consider this to be a long period so kick up and you should be entitled to a repair or at worst a partial refund.Look here basically the same Sub.
http://www.avforums.com/forums/showthread.php?t=436234&highlight=kef
Mar 04, 2008 | KEF Audio PSW 3000 Subwoofer
Subwoofer not working
if u are a technician then its easy to check, problems are, blown fuse, power amp IC output transistor may be blown, check for burnt componenets. changing and blowing a fuse means ur output IC or transistors are shorted.
May 15, 2007 | KEF Audio KHT 2005.2 System
403 people viewed this question
 Grubhead
Grubhead
