Initial pump out cycle to clear any residual water works ok, then fills with water ok but does not proceed to wash or start any pump for wash cycle. There is silence while the timer counts down. Seems like the wash pump motor is not being activated or motor is faulty. I would appreciate advice and a wiring diagram to help trace fault. Suspect Control Module presently but as I do not have a wiring diagram it is difficult to trace fault. Where could I get a wiring diagram for the SB915?.
SOURCE: I think I need to
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
SOURCE: stays in wash cycle
Solution found in a defective SPDT 'Heater ON' switch which had burnt out, thereby causing an 'open' to pump solenoid, fill valve, and heater. Temporarily bypassing the switch confirms the solution. Buy either the whole switch panel (3 switches) from parts dealer or find a source for CW Industries part GRS2012-13.
SOURCE: Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
