I have a relatively new (less than 3 months old) Harmon Kardon Receiver HK3490. It turns on but immediately turns off. You can hear a clicking sound like a breaker is disengaging. The problem started when the Niles speaker selector autoformer MSA-10A that was connected to it went bad. The ac power supply on the Niles shorted out. I've tried the reset button on the receiver but this does not correct the problem. Any suggestions?
    Sergeant:
  • 306 Answers
It is a relay clicking. You will need to obtain a schematic to troubleshoot this but they are available online. The protection circuits have been degraded from the short circuit but it is still alive and the discrete components are easy to replace. I used to use Sam's Fotofax but googling your HK model will get you alot of results. Harmon Kardon is a great brand and definitely worth fixing. ~Steve Medley
Posted on Nov 08, 2008
How to troubleshooting
prob with the audio amph on the motherboard
Dec 04, 2013 | Harmon Kardon Harman Kardon Harman/kardon...
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I have a Harmon Kardon HK3490 receiver which has an input for a powered subwoofer. Next to the subwoofer output is a "link switch" which turns on the subwoofer when I turn on the stereo. What...
Connect the Subwoofer Trigger Output for each subwoofer to thecorresponding trigger input on its amplifier. This enables the subwoofer toturn on or off together with the HK 3490. To further conserve energy,when the trigger connection is made, turn the Subwoofer Link Switch onto turn the subwoofer off when the corresponding pair of main speakersare not being used, such as during muting, when headphones are beingused, or when the main speakers are turned off using the Speaker 1/2 switch
Apr 05, 2011 | Denon AVR-687
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Harmon Kardon AVR 5
Assuming that the system is properly installed and was working ok before, the problem is usually a blown output amplifier in one channel and the receiver disconnects the speakers to avoid damaging them. In this case, professional repair is required.
Nov 15, 2009 | Harman Kardon AVR 5 Receiver
I have an AVR 335 less than 3 years old no sound
Hello
Yes, there is something you can try, to know where to look for the problem if this happens again. If the receiver is still under warranty, just send it back, otherwise, open up the amp and trace the path back from the speaker channel to the capacitors on each channel, this is usually the problem(you should be able to see if it is blown, cheap to repair).
If all the channels went out at the same time, there is something wrong with the central unit, to repair that, if it is not the above problem, cost expensive.
Hope this can help you.
Kind regards
Andrea
Nov 09, 2009 | Harman Kardon AVR 335 Receiver
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Harmon Kardon Receiver BUZZ
My receiver started having same problem after about 2 years from install. Any ideas?
Oct 14, 2008 | Harman Kardon AVR 110 Receiver
Harmon Kardon reel to reel tape player
I have a Harmon Kardon TD-3 that I'm looking to sell. It's not in its original cabinet, but in a smaller box that takes up less space.
Jan 12, 2008 | Audio Players & Recorders
Harmon kardon avr 25 II
hey i also had this problem, i don't know the name of these but they are basically plugs that you have to block output from the front rear and center speakers of the white/red cables... sry for bad description but its on the left side when looking at the back of the receiver, while all of the other speaker wires should be hooked up to the right with the twisting knobs... it took me forever to find this out but yeah it was a simple fix
Oct 28, 2007 | Harman Kardon AVR 25 MKII
369 people viewed this question
 Grubhead
Grubhead
