Question about Cameras
Droped Camera Broke the lock part on the battery door HP 215 still camera. I put duck tape to hold it closed. Could I order a new Latch.
    Scholar:
  • 121 Answers
Happy looking if you cant find it than i suggest u do plastic solder
take a small piece of hard plastic heat up the solder try to put the hard plastic at the place where the catcher had been and try to melt this plastic at its place
try hands on practice first for perfection
Posted on Nov 08, 2008
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Broken battery cover latch
The battery cover latch is broke how can we repair it
without having to use duck tape?
Apr 23, 2010 | Fuji FinePix S7000 Digital Camera
The orange plastic clip that holds in the battery broke.
use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
Hope this helps
Jer
Jan 16, 2010 | Pentax Optio T20 Digital Camera
One side of the door on my Fuji s300 where the card goes in has broken off. The other side is still intact. Right now I keep the door closed with a piece of duck tape. Can the door be replaced and where...
Didn't fix the problem. Part not available so duck tape will have to do until I'm forced into another camera. I like this camea but both Fuji's I purchesed had the same problem with a door. The other was the battery door where the tabs that kept the door closed chipped off so the door would not stay closed.
I will not purchse another Fuji.
Dec 02, 2009 | Fuji FinePix S3000 Digital Camera
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Lens locked in open position after batteries fell out
mine sometimes does that. 1.get a new cheaper camera. 2. use duck tape 2 secure the door.
Jan 26, 2009 | Kodak EasyShare CX4230 Digital Camera
Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Oct 07, 2008 | Kodak EasyShare DX7630 Digital Camera
Not turning on
Hello Ariel, You need a new battery lid. The problem is the lid has a pin that when closed properly, allows the battery to power up the camera. You can get one for $30.00 on Ebay item number 7623965577 if you act fast. This is a good camera and would be worth $30.00 (plus 5.50 shipping) to fix it. Please let me know how it works. Best regards, nightdiver
May 31, 2006 | Kodak EasyShare C340 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
