Question about SanDisk Sansa e200 MP3 Player
Formatting i have dis SanDisk Sansa 8gb and i mistakenly formatted it and turn it off during formatting and when i turned it on it goes to format (yes or no) and doesn't move. None of the keys will work only the hold and the power button. please help
  • deron_samuel Nov 08, 2008
    hey thanks alot...i tried that before i saw your msg but you were still helpful. I learn something, thx...God Bless
  • 47 Answers
Try plugging it into your computer. go to my computer, and double click sansa 260 (or what ever yours is) then you should see a drive called internal memory, right click and reformat . You'll still lose your stuff tho.
Posted on Nov 08, 2008
My SanDisk is 8gb and when I download photos the device reads unsupported media format. Please advise how to correct this Ralph Reiser
You need to use the supplied Sansa Media Converter program to convert photos (and videos) to a format the Sansa can handle. If you need the SMC, you can download it from
http://www.megaupload.com/?d=3IPZO6Q0
Oct 05, 2010 | SanDisk Sansa Fuze MP3 Player
I can't put pics on unsupported media format
you need to use the Sansa Media Converter to convert photos (and videos) to a format the Sansa can handle. o to the Sandisk site look under support.
Apr 18, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
How to format 8 gig scan disk for mp3
How to format the Sansa View:
To format the player directly, follow these steps:
1. Select More from the Main Menu.
2. Select Settings/Options then System Settings.
3. Scroll down to Format and select it.
4. Select Yes to start formatting.
WARNING: Formatting the player will DELETE all the content you have
on the player.
The player can also be formatted using Windows Explorer or Windows
Media Player.
Dec 25, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
I mistakenly formated my mp3 player 1Gb when formating my PC
If there was any driver whit it install it or search the net for a suitable driver
Oct 10, 2009 | SanDisk Sansa m240 MP3 Player
Sansa mp3 won't work! ...rockbox
try this ...press and hold the Left button while turning on the player......if this do not work you really formatted (format = erase all) the mp3.......all you can if true find another sansa and copy the software (not music) to pc then to sansa
Apr 14, 2009 | SanDisk Sansa e200 MP3 Player
Not working
I had the same problem. I re-formatted the player, and now it works fine. Sure, formatting erases all the music, but at least it works now!
To format, just go to "My Computer", find your player in the list, right click on it, then select format.. you're done!
Apr 11, 2009 | SanDisk Sansa Clip MP3 Player
Home video from computer does not show on my
its an unsupported format try to convert the videos to mp4 i am 100% sure it will work if u convert them to mp4(mpeg-4) format
Jan 15, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa e260 freezes up
It's not suppose to say Refresh Database when you connect it to the computer, it's only suppose to say that when you eject it OUT of your computer.
Did you load a massive amount of files during your last sync?
I don't think there's any need in resetting it if it is able to turn off and on. What I recommend doing is formatting it. Remember, formatting the player will cause you to loose ALL your media stored in the device. To format go to "My Computer" > "Sansa e260" right click and go down to format.
If it formats, then good. Turn it on and it should say "Refresh Database". Change the mode of your player to MTP(?) so that it will no longer refresh the database after transferring media(?).
Connect it back to your computer and reload your media onto it that was wiped out during the format. Now disconnect it and see if it works... It should.
If that doesn't work this should do the job for you: http://sandisk.com/Retail/Default.aspx?C...
Always remember to update the firmware on your products, it is a wise idea to do so. (: http://sandisk.com/Retail/Default.aspx?C... < Get updates with that.
Drain the battery if whatever you do don't work. Sometimes removing the battery for a few seconds on putting it back in works.
If you think you attacked this problem from every angle and still no luck. Contact sandisk: support@sandisk.com Give them some time, their swamped with emails at the moment.
Jan 27, 2008 | SanDisk Sansa e260 MP3 Player
Bad Track
Change the Mode on the device and try to format again.
SETTINGS>MODE or USB MODE.
If that doesnt work. This will;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 19, 2007 | SanDisk Sansa e250 MP3 Player
It shows Sandisk logo and freezes there
Remove the SD card and try this;
Best of Luck.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
