Question about Cosco Baby Gear
Seatbelt How does the seatbelt go in properly after removing the cover to wash??
You just put it back together the same way you took it apart not that hard i did it with mine
Posted on Nov 08, 2008
How to remove seatbelt pillar covers in a 2002 tacoma standard cab
big screwdriver and wrench them the covers are held in with plastic clips and they will break on pulling the covers thats for sure but the new clips are not expensive from a motor factror who now have a trico catalogue
Nov 16, 2013 | 2002 Toyota Tacoma
How do you replace a seatbelt in a 98 Toyota tacoma
Check this generic procedure:
1. Follow the harness side of your seatbelt (this is the side you pull across your shoulder and lap to connect to the anchor side) to the points where it connects to the car frame.
2. Using a flat head and Phillips screwdriver, unscrew and pry off any plastic housing that is covering the bolt connections. Select a socket that will fit the bolt and attach the wrench to the bolt.
3. Feel underneath the car for the other end of the seatbelt bolt. Fit a box wrench to the nut and hold it still while unscrewing the bolt with the socket wrench inside the car.
4. Unbolt the shoulder attachment of the harness with a socket wrench. Remove the harness side seatbelt from your Toyota Corolla.
5. Install the new harness side seatbelt by reversing the removal steps, however, make sure to use the new hardware provided with your replacement belt.
6. Feel down at the bottom of the anchor side of your old seatbelt. There will be one bolt and nut attaching it to the bottom of the car. Remove the bolt using a socket and box wrench.
7. Install the replacement anchor side. Before you tighten the bolt, connect the seatbelt and make sure that you have the anchor side facing the correct direction to receive the harness. When it is right, tighten the bolt.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 09, 2012 | 1998 Toyota Tacoma
Warning light came on this morning, figure of a man with the seatbelt. What does this indicate?
This is the seatbelt indicator, its not seeing that your seatbelt is fastened ifthe light stays on and the chime keeps going off.
There is a switch inthe seatbelt that closes when the seatbelt is buckled, and if not, thelight stays on and the chime goes off.
There are a couple reasons thiscould happen. It could be a wiring issue going to the seatbelt buckle,or more likely the buckle itself. Your truck is pretty new, so if youare under 36,000 miles the repair would normally be covered underwarranty.
Also, I suggest check the Repair Manual for Jeep-WK-Grand-Cherokee-Section-08O-Restraints (page 473 and next, for Seat Belt)
Hope helps with this (remember rated this) Good luck.
Jan 21, 2010 | 2006 Jeep Grand Cherokee
How do you fix a stuck seatbelt in front seat passenger side? The seatbelt has retracted but will not release outwards to enable its use. We have pulled off interior cover of the seatbelt to get access to...
this is a simple repair many dont know. remove or pull off plastic pillar post cover, seatbelt probably twisted inside. twist it back around so it runs flat and lube slightly with a light lube spray on metal gearing. i had the same problem w mine pk
Jan 16, 2010 | 1998 Ford Taurus
1999 ram 2500 4x4 seatbelt light on -not flashing- stays on even with seatbelt on.
check the conectors on the buckels if it's ok then remove pillar cover and check the conector on belt winder
Jan 04, 2010 | 1999 Dodge Ram
Seat belt stuck on 1995 850 volvo
I solved this on my 95 volvo 850 glt as follows:
pull the seatbelt pilar cover off from the door jamb. this runs vertically up the pilar between the front an back door (beside the front seats. Once opened loosen the belt by gently pulling the belt upward toward the roof. You'll have to do this sometimes in small increments. Once the seatbelt is pulled out all the way, spray small amount of lubricant into the joint where at the top of the belt spool. Also use a screw driver to push spool upward while pulling the belt. At first it's only going to release a little but eventually the lubricant will work its way into the seam at the top of the belt spool and loosen up the stuck inertia catch. Until it completely loosens you might have to remove the pilar cover again and work the seatbelt out (also use the screw driver technique described above) in order to use the seatbelt. When parking, I would relatch the seatbelt and pull the slack up around the back of the head rest. After a day or so it worked normally.
Dec 31, 2009 | 1996 Volvo 850
I took off the cover to wash and now I'm trying to figure out how to get straps put back on
This will help if you lay out the chest pieces and all the pieces you removed on the table first. If it helps, snap them together. Then, lay out the pieces with metal prongs that lock into the buckle that goes between your child's legs.
1st pull through the belt adjusting piece through the bottom cover ****.
2nd pull the square release buckle through the second ****, on top of the piece that tightens and releases. This is the piece that you push with your thumb to release the seatbelt.
3rd pull both side seatbelts through the respective side right and left and make sure they are flat.
4th slide on the two pieces with metal prongs on one left and one right seatbelt. Before you do this, ensure that you have put the correct piece on the correct side and that they will latch properly into the buckle. Snap them into the buckle to ensure you have it right.
5th attach the two respective chest clips on one right and one left seatbelt. Snap them together to ensure you have it right.
6th pull the top shoulder seatbelt straps through one of the top cover slits. If you have a newborn, then it will be the bottom **** at the top. If your child has grown, then it will be the top two slits. Ensure both seatbelts are pulled either through the same **** on either side.
7th after you have pulled the shoulder straps through the top slits on the cover, pull them through the slits in the plastic carseat frame. Pull them through until you see them at the rear.
8th attach on their respective sides the shoulder strap at the back of the plastic carseat. There is a big brass metal piece with "hooks" at the top. The shoulder strap has a seatbelt "loop" on one end that can be hooked on. Do this on each respective side and make sure it is secure.
Oct 26, 2009 | Graco Snugride
Automatic seatbelt 1994 saturn
You may have to replace the seatbelt positioner.
Check with Saturn (or their replacement GM division) to find if the warranty is extended for seatbelts (some manufacturers cover seatbelts forever) 800-553-6000
Jul 13, 2009 | 1994 Saturn Sl
2000 Ford Focus; seatbelt alarm problem
check the sensor inside the seatbelt anchor.. it's probably not contacting properly
Mar 15, 2009 | 2000 Ford Focus
Rear passenger side seat belt is stuck, and I can't work out how to get to the mechanism without damaging the seat.
If it is a 850 sedan like mine then you'll have to remove the speaker covers and then pull up the rear deck cover, then you can get to the mechanism.
Jul 27, 2008 | 1996 Volvo 850
Baby Gear Logo
85 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
