Question about Motorola Mobility RAZR V3i Cellular Phone
Screen show"connect to usb"what should i do?need to format?
    Problem Solver:
  • 3 Answers
Im pretty sure your phone will only show up in my computer if u have a MicroSD Card
and you need to format it from your phone...
Posted on Nov 12, 2008
How does the usb work (for reading movie clips from an external hdd?) can't get it to work.
When you go to the File Explorer ( an icon on the lower bar showing a set of FileFolders inside of a support holder (yellow folders/ with a blue holder Icon) Left click on the ICO and all of the attached devices will show up on the desktop screen. If the external hard drive is showing up (could be Drive G or H for example) it is connected, however if the attached drive was not formatted the drive will not open for business. New attached drives need to be partitioned and formatted prior to use.
Dec 24, 2013 | LG RH299 DVD Recorder/VCR
Format my gps usb restart show logo and restart
Well to avoid this problem you can do a hard reset, that reset set all the settings to factory default and it again format in fat file system, Turn the unit off. Hold your thumb on the bottom right of screen and turn it on, keeping your thumb there. Say "Yes" when prompted. Please post comments if further you have the same problem......
Good Luck!!
Thanks
Feb 15, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
Psp 300 doesn,t show the usb mode when connected to PC.It keeps showing Please wait .No problem with usb cable,port.
Hi rimoricky, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 16, 2010 | Sony PSP-3000 Silver Console
Device not working/screen shows installation driver problem
You can try to format the disk NTFS File system.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format NTFS files system.
hope this help you
Regards
uttam
Dec 27, 2009 | Western Digital Elements powered by WD 320...
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Having trouble synching with gpx ml638b...
If this problem occurs then your ML648B needs to be formatted.
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Jan 05, 2009 | GPX ML648B MP3 Player
Snoy NW-E105
I had the same problem and struggled with it for some time. I forgot the format feature on the device itself and kept formatting from my pc. This won't work.
The solution:
1. Unhook your device from the pc by pulling out the USB cable.
2. Click the "Menu" button 1 time (found on the back of your NW-E105 player).
- This will show "Display"
3. Click the " |<< " button 3 times (the button to rewind track).
- This will show "Format"
4. Click the Play/Stop button 1 time.
- This will show "Format: N"
5. Click the " |<< " button again 1 time.
- This will show "Format: Y>
6. Click the Play/Stop button 1 time (wait for "really?" prompt), click it again.
Now your device is formatted and will play the files you add to it.
Oct 07, 2008 | Sony Network Walkman NW-E105
1 gb usb
Hi
You need a format your USB drive!!!
Plug in USB drive and in MY COMPUTER right click on the USB drive!!! Select format and that will do it!!!
Good luck!!
Jan 29, 2008 | Kingston (SDCZ2-512-A10-KT)...
Motorola Mobility RAZR V3i Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
